poor handling and ture pressure
lnewland
PostPosted: 21:20 - 25 Apr 2009    Post subject: poor handling and ture pressure Reply with quote
Hey all,
how often do you all check your tyre pressures.
i checked mine on Thursday night and both the front and back were about psi below what they should be, i took the bike out and covered about 30 miles. on the route back i was finding that when taking right bends the bike felt like the back wheel was sliding out or rolling on the tyre. Well i checked the pressures today and they were both approximately 4 psi below. I appreciate the weather has got some what warmer but should my tyres change in pressure that much (they have been checked when cold)
also is it the tyre pressure that aremake the bike feel unstable. Im not hammering the corners by the way
Cg125 stolen and returned trashed
Cb500
Yamaha R6
PostPosted: 21:24 - 25 Apr 2009    Post subject: Reply with quote
I check mine about once a week, occasionally need a couple of pound back in them. What tyres do you have, and what pressures you putting in them?
lnewland
PostPosted: 21:46 - 25 Apr 2009    Post subject: Reply with quote
i am putting 36 front and 40 rear
not sure on what make the tyres are i shall check tomorrow
Cb500
Yamaha R6
That_Hornet
PostPosted: 21:50 - 25 Apr 2009    Post subject: Reply with quote
I really do need to get one of those tyre pressure things. I got the one on the pump. But its not 100% right as it like 6 years old.
I don't check mine often enough....... Neutral
Villers
PostPosted: 10:05 - 26 Apr 2009    Post subject: Reply with quote
I check mine everytime I remember to. My bike seems to react quite a lot to low pressures, more than my other bikes have done anyway.
I got my new hoops on a few weeks ago and after a hundred or so miles I was blasting along at a fair rate and the front started to feel very wobbly. A quick check when i got home showed just 32psi in the front. Its supposed to be 42psi front and back.
If you get a pressure tester make sure its got a right angled adaptor on it as this will make it easier to get onto the valve Thumbs Up
Oh and don't trust the free air machines at places like tesco, our local one is about 5psi out. The ones you pay for should be better but I would still take my digital gauge with me as a reassurance check Wink
lnewland
PostPosted: 15:08 - 26 Apr 2009    Post subject: Reply with quote
Thanks guys. For the answers. If it's not the tyres that are causing the instabilty what else could it be
Cb500
Yamaha R6
ajb
PostPosted: 15:54 - 26 Apr 2009    Post subject: Reply with quote
lnewland wrote:
Thanks guys. For the answers. If it's not the gyres that are causing the instanilty what else could it be
When I had a CB500, manual stated for driver only it was 29psi Front / 33psi Rear. (driver+passenger was 29psi Front / 36psi Rear).
I would say try letting them down a bit.
CBR125R '05 > CB500 '00 > CBR600F '99
iooi
PostPosted: 16:01 - 26 Apr 2009    Post subject: Reply with quote
When the mood takes me....
But as it happens after fitting a new chain today, i decided to check them.
Handling has been as bad as ever on the Avon Roadriders....
Read 25 front & 36 rear.
Should be 33 front and 40 rear according to Avon. So i have pumped them back up again. Will see how it handles tommorow on the way to work.
Must have been at least 3 months since last check... Confused
PostPosted: 18:11 - 26 Apr 2009    Post subject: Reply with quote
Unless they are BT45s, where you want 36 front and 42 back. Bridgestone issued updated pressures after further testing.
lnewland
PostPosted: 18:32 - 26 Apr 2009    Post subject: Reply with quote
in response to the earlier question i have a avon roadrider on the front which i put 36psi in and a continental conti go on the rear which i put 40psi in. tyre pressures i got from honda
Cb500
Yamaha R6
ajb
PostPosted: 19:47 - 26 Apr 2009    Post subject: Reply with quote
They were BT45s, and I never knew that. Confused
Bru
PostPosted: 21:30 - 26 Apr 2009    Post subject: Reply with quote
Do try to check your pressures when your tyres are cold, ie. before you ride off. If you ride a mile or two to the petrol station, your tyres will have heated up a bit, and your pressures will be incorrrect.
Flip
PostPosted: 22:02 - 26 Apr 2009    Post subject: Reply with quote
Eek. I haven't checked mine for a while...
*Note to self...
Check tyre pressures tomorrow! (Car & bike!)
I had to post this or I'd have forgotten!
The last post was made 16 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.34 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 78.2 Kb
