| Mafizzle |
 Mafizzle Two Stroke Sniffer
 Posted: 09:53 - 26 Apr 2009 Post subject: RS125 Idle Screw |
So my bike doesn't idle very well at all, even when it's warm.
I'll pop the clutch in at a junction and once i'm under 1000rpm she just says no and goes to sleep.
I've been told to adjust the idle screw, where abouts is this on the RS125? I've had the side fairings off, i'm thinking it's around where the throttle cable ends up, the black twisty knob? Wasn't sure if it was fuel/air mixture or something/
Don't want to go playing too deep, these are fickle machines!
Thanks in advance to Keith most probably  ____________________ Aprilia RS125 |
| Kickstart |
 Kickstart The Oracle
 Posted: 10:04 - 26 Apr 2009 Post subject: |
Where the cable goes into the carb it connects with the slide. The slide is a tube that goes up and down inside a vertical tubular part of the carb. You will see a screw (quite possible with a black plastic knob on it) to adjust the idle speed. Screw that in clockwise to raise the idle speed (only a small amount).
Basically the screw has a pointed end and a bit at the bottom of the slide is cut at an angle. As you screw the adjuster in it pushes onto the bit cut at an angle and so lifts the slide up a bit.
| Mafizzle |
| Mr.Ormes |
 Mr.Ormes Nova Slayer
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 13:26 - 26 Apr 2009 Post subject: |
hi,
if the idle adjust screw still has the plastic cover/knob on it, then you dont need to use a screwdriver.
in fact i wouldnt risk a screwdriver, you dont want to force it in too far & damage the slide.
turn the screw anti-clockwise, all the way, until it comes out.
inspect it, does it still have its pointed end?
it might need replacing, though i very much doubt it, unless ts damaged.(i havnt seen many wear away)
if it looks ok & is complete/un- damaged,then remove the slide, is that ok? (undamaged & not have a huge indent where the idle screw has been forced in)
i would then be tempted to remove the carb.
clean it out & return to stock settings & start from there.
cheers,
GAZ |
| Vincent |
 Vincent Banned
 Posted: 18:38 - 26 Apr 2009 Post subject: |
I know it's difficult when the bike won't idle, but you should set the tickover,(idle), while the motor is running. Also, if the bike is cold, it might not tickover properly until the engine is warmed up, this is more the case with two strokes than 4 strokes. If turning the screw right in isn't making any difference, then something must be wrong somewhere. Do you have any pics of the carb, (the bit where the throttle cables go in)?
Has anyone had the carb apart recently? Could be that your main jet needle needs raising a bit. or, as above, the pilot jet needs cleaning. ____________________ Space Is Deep |
The last post was made 16 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
