yamaha dt125x
benjy bwoii
PostPosted: 12:40 - 25 Jan 2009    Post subject: yamaha dt125x Reply with quote
hello im thinking of buying a dt125x when im 17 and i was thinking of putting a full dep race pipe and a reed block and ive heared the 170cc big bore kits are good does any one know what sort of bhp i could reach.thanks.
Ariel Badger
PostPosted: 12:45 - 25 Jan 2009    Post subject: Reply with quote
6.73 hp, then it will go bang.
stevo as b4
PostPosted: 22:43 - 25 Jan 2009    Post subject: Reply with quote
If a de-restricted DTX is a true 18bhp at the r/w, and the pipe etc makes it around 20bhp, then i think you'd have to be looking at around 25-26bhp with a 170cc kit. Bear in mind this would put it at maybe 30bhp+ at the crank, so it's pretty good IMO.
There are issue's with fitting a big bore kit to any bike, and if you were hunting every last bhp, then the std carb would be too small, the ignition advance curve would not be ideal, and the pipe volume would be too small. But ignoring all that because it's silly cost to change and optimise every other aspect of the engine to suit the 170cc kit, and i think you'd be impressed with the performance.
Would expect some increase in engine wear and heat created, so it would need more looking after, regular maintainence and probably top end re-building at around 6-7000miles, to be on the safe side.
How much is a 170cc kit for the DT motor?
benjy bwoii
PostPosted: 12:34 - 26 Jan 2009    Post subject: Reply with quote
cheerz m8 for you help whats the best upgrade carb for a dt125x with a 170cc big bore kit.cheerz m8
stevo as b4
PostPosted: 21:48 - 26 Jan 2009    Post subject: Reply with quote
All i know is that the Mikuni TM30SS will bolt on to any bikes inlet stub that originally had a VM26/28 carb or TM28 carb. I don't know what size carb would best suit a 170cc kitted DT engine, have never tried it! The TM30 seems to make the KMX125 engine go better, and i'd say a TM32 from an early RGV250 would not be a bad carb to use, if you can get it mounted easily and then tune it to suit.
That_Hornet
PostPosted: 22:09 - 25 Apr 2009    Post subject: Reply with quote
What do you think the max bhp you could get from a dtx, 170 kit and all the works.
Planning a project and i want to keep it under 33 but as close as possible.
Thanks
Hornet
PostPosted: 22:29 - 25 Apr 2009    Post subject: Re: yamaha dt125x Reply with quote
Why go for a big-bore DT? From acedotal evidence, something like a KTM EXC will be just as reliable; it also weighs less, has better suspension and even the 125 makes more power than than that.
Finglonga
PostPosted: 14:52 - 26 Apr 2009    Post subject: Re: yamaha dt125x Reply with quote
By reading B,B's posts he was a tad obsessed with a 70cc kit for his 50 so much so the moped was off the road longer that it was on . Wink
Even if he does, if he hasn't passed his test he will be riding round unlicensed and uninsured.
Andy Sez....
F.Y.Y.F.F.
element
PostPosted: 15:01 - 26 Apr 2009    Post subject: Reply with quote
athena big bore is around £400+, then would need bigger carb, airbox mods to suit, ignition remap blah blah.. would cost an arm and a leg for the sake of a few extra bhp at a big expense of reliablility.. I doubt the crank would last long either so thats major engine rebuilds (not just top ends)..
also get caught with that on a prov license and you will get a spanked ass bigtime.. only takes an accident and the insurance companies get involved.. your insurance = null and you will be up sheet creak without a paddle..
and anyway if your gonna go that far you might aswell find a dt230 lanza and use the engine out of it (engine is the same as a dt125x).. even then you'd need the carb, cdi etc but it would be less hassle and probably cheaper..
also a stage 3 tune at stan stephens is only £150.. wouldnt be that far behind a 170 big bore and would be waaay cheaper
EDIT
£500 for a big bore Shocked
https://www.pjme.co.uk/acatalog/Yamaha_DT125R_Engine_Parts_Top_End.html
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
chillpill
PostPosted: 15:30 - 26 Apr 2009    Post subject: Reply with quote
ive always wondered what the stage 3 tune includes , im guessing its just mostly a bit of barrel work and the head skimmed or something nothing too fancy
The last post was made 16 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 64.89 Kb
