Tip when bleeding brakes
squishio
PostPosted: 10:28 - 27 Apr 2009    Post subject: Tip when bleeding brakes Reply with quote
Last time I tried bleeding my brakes I failed and the brakes just felt like they were full of air.
So I ended up taking it to the dealers to get it done.
I thought I would try again this weekend.
So I fitted my new pads and then went about flushing the system of old fluid.
I got some out but the lever just kept pumping and not getting harder.
I spent a good 45minutes trying to figure out where I was going wrong.
I had topped up the reservoir and replaced the cap before I started pumping. Big mistake was replacing the reservoir !
So whilst pumping it was creating a vacume in the system and not pushing out any fluid or air. As soon as I took off the cap the lever almost instantly went solid Smile
So lesson learnt - Leave the res cap off whilst bleeding brakes !!!!!
Prior to doing the brakes I bought one of these...
https://cgi.ebay.co.uk/MOTRAX-LITTLE-BLEEDER-MOTORCYCLE-BRAKE-BLEED-KIT_W0QQitemZ180313165592QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item180313165592&_trksid=p3286.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
What a fucking waste of money!
The valve is not completely tight so fluid still goes back down the pipe.
But even worse is that when I undo the bleed valve and start pumping the fluid leaks up around the valve thread, So if it is leaking out then I guess it is also sucking air in.
So I ended up opening and closing the valve manually Sad
Does anyone else have this problem?
I was not releasing the valve very much, just enough to break the seal to let fluid out.
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
Mark65
PostPosted: 10:42 - 27 Apr 2009    Post subject: Reply with quote
When i did my changed the fluid on the front brakes on my ybr i just used the old style 1 way valve from halfards for a fiver, run it into a plastic container with some fluid in then raise the container and tube or at least the tube above the bleed valve then when you pump the brakes all the little air bubbles will rise away from the valve,where as if it is lower they will rise back to the caliper.
But i would like one of these:
https://www.workshopsupplies.co.uk/index1.html
They do a plastic one as well for about half the price.
Mark
PostPosted: 10:49 - 27 Apr 2009    Post subject: Re: Tip when bleeding brakes Reply with quote
This shouldn't be the case. If it was then your brakes would rapidly stop working as the pads started to wear.
Under the reserviour cap there should be a rubber diaphragm, and the cap should allow air above this. As fluid is used the diaphragm should move down, basically allowing air to take the space vacated by the fluid but keeping that air seperate from the fluid.
Problem you have suggests either the diaphragm is fully extended, the breather above the diaphragm is blocked or the diaphragm itself has harden and won't move.
squishio
PostPosted: 10:59 - 27 Apr 2009    Post subject: Reply with quote
Sorry yes, Keith you are exactly correct.
The rubber diaphragm was fully extended, as when I first started some fluid was pushed out but then it stopped presumably when the diaphragm had been sucked down.
loply
PostPosted: 12:20 - 27 Apr 2009    Post subject: Reply with quote
Incidentally, by far the easiest and most effective way to bleed, as well as the cheapest (and also the best way to refill an empty system) is using RFI (reverse fluid injection) and a syringe.
Go on ebay and buy a 100ml plastic syringe, and get yourself 20cm of clear plastic tubing (B&Q sell it).
Slide the tube over the syringe, fill the syringe with fresh brake fluid, squirt the air out and then squeeze the fluid into the bleed nipple on your caliper.
The resevoir at the top will slowly fill up and the odd bubble will appear.
Do this for 10 mins and voila! Just be careful as the resevoir will fill up and require periodic emptying as you go...
Yamaha SZR660 Caution to the wind, the throttle pinned!
squishio
PostPosted: 18:00 - 27 Apr 2009    Post subject: Reply with quote
what about the air in the top of the caliper around the bleed valve?
PostPosted: 18:11 - 27 Apr 2009    Post subject: Reply with quote
There shouldn't be any as you've filled it from that point, and it's not the highest point of the system.
squishio
PostPosted: 20:47 - 27 Apr 2009    Post subject: Reply with quote
but it's the highest point of the caliper and the syringe isn't going to push all the air out in one go.
So if you have got the syringe attached no air is going to come out that way and the injected fluid is not going to suddenly push the air down and then up the brake hose is it?
I can't say my knowledge is great so I may be wrong but common sense tells me that the air will not be pushed down.
stirlinggaz
PostPosted: 21:01 - 27 Apr 2009    Post subject: Reply with quote
hi,
im not understanding this....
when i use the big syringe (best 2 quid ever spent), its pushing all the air upwards into the mc & replacing it with fresh brake fluid.
so there shouldnt be any air left in the caliper...no?
if there is, once you've disconnected the syringe/hose.
1 final crack of the bleed niple should expel it.
i've just done 3 or 4 calipers with 100ml syringe & 8 inches of washer tubing, took hardly any time at all.
wouldnt do it any other way now.
cheers,
GAZ
salty21
PostPosted: 22:01 - 27 Apr 2009    Post subject: Reply with quote
is it common practice to use the same syringe for for sucking the old fluid out the res? and if so would you need to suck it dry after each syringe full of fresh to make sure the system is using as much new fluid as possible without stripping the calipers.
on a side note, i noticed on my bike that during hard riding/braking the brake lever will sometimes pull all the way to the handlebar and not slow me as much as i want, which is not really ideal Laughing
have read a few posts on brake issues and to me it sounds like fluid boiling?? which cant be a good thing.
If so is this usually caused by the fluid being contaminated with water?
loply
PostPosted: 22:14 - 27 Apr 2009    Post subject: Reply with quote
Contaminated or old fluid will boil more readily than new fluid.
Generally if it boils the brake will pretty much stop working all together, not just become weaker.
Like... the lever comes to the bar, and NOTHING happens.
If you're still getting some action I'd be inclined to suggest it's not that? Either way, flush some new fluid in to be sure...
c-m
PostPosted: 22:16 - 27 Apr 2009    Post subject: Reply with quote
i have cleaned up my calipers and installed new pads,. spent ages the other week bleeding my brakes but they are still spongy despite my improved stopping power
PostPosted: 22:24 - 27 Apr 2009    Post subject: Reply with quote
The quickest and easiest way to bleed your brakes is to use a Sealey vacuum brake bleeding tool. But you do need a compressor.
PostPosted: 08:39 - 28 Apr 2009    Post subject: Reply with quote
The way I see it the caliper will fill up, but the fluid will not start to be pushed up the actual brake line until the caliper is completely full.
I see what you mean, but can't see how it would be true for a reverse bleed.
PostPosted: 10:10 - 28 Apr 2009    Post subject: Reply with quote
I am not sure that I can see how with amost calipers you would dislodge air from the top of the caliper and push it up the hose by pushing fluid in with a syringe. Most calipers there is a bit of volume that will be higher than the entry drilling for the brake hose. Push fluid through the bleed nipple and it is likely that any air trapped there will stay there.
loply
PostPosted: 10:34 - 28 Apr 2009    Post subject: Reply with quote
If the design of the caliper is bad and the bleed nipple isnt the highest point, then obviouslly you just have to rotate the steering or lift the front or remove the caliper and make it so...
If the designers had any sense though the bleed nipple will be the highest point by a reasonable amount.
Incidentally you make things easier by pushing all the pistons fully in before doing this.
norstad34
PostPosted: 23:26 - 30 Apr 2009    Post subject: Reply with quote
Hello all,
I have also tried the reverse method and it works a treat if you have an empty system, I also bleed it normally after I have backfilled it just to make sure, maybe that's just me and my nobrakesaphobia.
caught at 105 gutted
Mark65
PostPosted: 09:28 - 01 May 2009    Post subject: Reply with quote
Yes the fluid gets contaminated with small amounts of water that is absorbed over time, now i believe fluids cannot be compressed but when the temperiture gets too high the small amount of water in the brake line turns to gas and bam brakes fail then when you try them after you come off they seem to work because they have cooled and the water reverts from the gas to to a liquid again.
So if you use DOT 4 fluid you cold try DOT 5.1 fluid wich has a higher boiling point and may help.
BEWARE that DOT 5 is silicone based fluid and 5.1 mineral based.
Please spank me and correct me if im wrong Shocked
Mark
Ichy
PostPosted: 09:39 - 01 May 2009    Post subject: Reply with quote
Absolutely no reason to use dot 5.1, plain ordinary DOT 4 is fine. In fact DOT 5.1 attracts water far more readily than DOT 4 even in a closed system so you would have to change it more frequently.
BTW DOT 5 is silicon based, DOT 5.1 is still polyethylene glycol based.
PostPosted: 09:45 - 01 May 2009    Post subject: Reply with quote
It still has a higher wet boiling point so should still be better than DOT 3 or 4 after a couple of years.
Mark65
PostPosted: 10:21 - 01 May 2009    Post subject: Reply with quote
I stand corrected on the 5.1 make up but i have not seen any info that says it absorbs more water faster? as i put it in my car, so itchy gets a partial spank lol Rolling Eyes
Mark
Kal
PostPosted: 10:39 - 01 May 2009    Post subject: Reply with quote
I use DOT4 - not a got a clue what that means but the bike likes it.
I made a brake bleed kit from some petrol tubing and an old syringe - cost nothing, but works nicely. Thumbs Up Last time I did the job I back filled it, worked nicely.
I also found that using a cable tie to keep the brake pulled overnight was helpful.
Kal...
Ichy
PostPosted: 17:31 - 01 May 2009    Post subject: Reply with quote
Very hard to say. Its more hydroscopic so needs changing more frequently. No idea at what the crossover point would be. I can have a look when I get back to work.
For me the important point is that the braking system was designed to work with DOT 3 or 4. The fact it doesn't should not justify going to DOT 5.1, your not fixing the problem.
Ichy
PostPosted: 17:44 - 01 May 2009    Post subject: Reply with quote
Mark
Want to put that in English?
I thought it was fairly common knowledge that the only downside to 5.1 was that it required changing more frequently? Even adverts selling the stuff tells you that much
https://www.carpimoto.it/product/Lang_EN/Chan_1/Brand_0/Bike_0/Firm_0/Prod_759.htm
I guess that in a normal car you probably wouldn't notice the difference until after 3 or four years since you will be hardly putting the sytem under any pressure.
PostPosted: 17:55 - 01 May 2009    Post subject: Reply with quote
As far as I can find the wet boiling point is meant to represent the fluids boiling point after exposure to moisture equivalent to a couple of years of use, which is about 3.5% water. Should be a fair margin for error with the wet boiling point of DOT 5.1 being about half way between the wet and dry boiling points of DOT 4.
The last post was made 17 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 137.89 Kb
