| loply |
 loply World Chat Champion
 Posted: 15:32 - 27 Apr 2009 Post subject: DIY LED Tail Light? |
Hi folks,
The bulb holders on my Milles tail light are a bit gnarled (barely make contact) and each time I replace the bulbs they become more sensitive. I've fiddled with them but its a bad design and supporting plastic is snapped/missing, making it hard to fix. Now one of the bulbs won't come on reliably and the other is suspect too. It makes me nervous at night incase they both suddenly go off.
A new holder is £45 from Aprilia. I'm thinking instead of hacking the bulb contacts off and soldering/epoxying in a bunch of LED holders and hooking up some ultrabright 12v LEDs instead.
There are three wires going in... I guess one is ground, and there's one each for tail and brake, right? It should be easy enough?
Anybody see any pitfalls or potential problems here? My idea is to use two bright white LEDs in place of each bulb filament, ie two for the tail and two for the brake... But there's two seperate light pods so that means 4 LEDs for the tail and 4 for brakes in total.
I'm going to pull out the copper contacts and epoxy in a cluster of LED holders where they go, then solder it up as required.
Should be bright enough? Can't see why its not surviveable, should last easy enough? The lights are covered with a red lens so I presume I should just use white LEDs?
Thanks for any tips or wise advice. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Ichy |
 Ichy World Chat Champion
 Posted: 15:42 - 27 Apr 2009 Post subject: |
All sounds fine. Wires are as you said. Just remember that you will need resisitors as well.
I guess one other option is to buy some led tail and brake bulbs, solder the wire directly to them and epoxy in position. I got some cheap, £3 for 2, ones off ebay and they were just fine. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| loply |
 Posted: 15:52 - 27 Apr 2009 Post subject: |
Presumeably if I wire the LEDs in parallel I can just put one resistor on the ground for each light pod connector thing?
I've forgotten how to calculate the size of that resistor mind but I'm sure I'll figure it out... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| loply |
 Posted: 15:58 - 27 Apr 2009 Post subject: |
Aye I see you can get them on ebay for real cheap, probably costs less than buying the LED's from Maplins!
That's a better option, then just solder and epoxy in position as you said....
Presumeably they should last virtually forever? Obviouslly once it's done it'd be a pain to change... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| mikey 2659 |
 mikey 2659 Borekit Bruiser
| KevTM |
 KevTM World Chat Champion
| mikey 2659 |
| Phoenix |
 Phoenix Twisted Firestarter
| adamck |
 adamck Crazy Courier
The last post was made 16 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
