oil filter tension
flumpy7
PostPosted: 19:22 - 27 Apr 2009    Post subject: oil filter tension Reply with quote
Hi guys, i have always had bikes that i have used simply as work hacks and have serviced them myself. As i was never particularly concerned about keeping them nice i always used to tighten new oil filters to hand tight, and it never seemed to be a problem. I have just picked up a 1999 suzuki gsx75-f katana that is immaculate and only 12000 on the clock. I would like to try and keep it unspoiled and was just wondering do i really need a filter wrench or is it safe to just keep using my hands? Thanks in advance[/quote][/list]
PostPosted: 19:27 - 27 Apr 2009    Post subject: Reply with quote
Generally probably best to just use your hands. Torque on them isn't much and over doing them will result in them being pigs to get off.
The wrench can make removing the filters easier though.
PostPosted: 11:56 - 28 Apr 2009    Post subject: Reply with quote
As Kickstart says personally I just use my hands.
I use a filter wrench to get them off.
After you've hand tightened it and filled it with oil just give it a quick run up to check for leaks, and to re-check the oil level after you've run it. If you're really worried about it coming undo you could always put a hose clip around the filter and then lockwire to a nearby bolt, but I've never bothered on road bikes.
Finglonga
PostPosted: 14:33 - 28 Apr 2009    Post subject: Reply with quote
In addition to what has already been said I always put a thin coating of oil on the O-ring on the filter so it doesn't seize to the engine block and make it impossible to remove.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:17 - 28 Apr 2009    Post subject: Reply with quote
Also make sure you're removed the old o-ring from the block before spinning the new filter on or you'll find out just how high the flow rate of your oil pump is when you first blip the throttle (high enough to empty the sump in about 5 seconds!) Embarassed
Finglonga
PostPosted: 15:30 - 28 Apr 2009    Post subject: Reply with quote
Mr. Green
Andy Sez....
F.Y.Y.F.F.
flumpy7
PostPosted: 08:22 - 29 Apr 2009    Post subject: Reply with quote
thanks guys.....hands it is!
The last post was made 17 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 52.68 Kb
