| Itchy |
 Itchy Super Spammer
 Posted: 21:18 - 28 Apr 2009 Post subject: Camping in a thunderstorm |
I was watching a video of Kazakhstan and Mongolia and there are regions which are flat and completely barren of trees and such like.... then it started showing 'climatic' changes to the regions such as the desertification of Mongolia and such which has caused more severe thunderstorms in recent times.
Erm my tent has alloy poles which stick into the ground or touch the ground, while my bike has insulating tyres meaning its somewhat likely a bolt of lightening may hit my tent.
So on a completely barren Steppe / sub desert area what is the threat from being fried by lightening? . My gut tells me that it will hit the alloy poles and conduct semi harmlessly into the ground with the extreme heat caused by this setting the body of the tent on fire. But my overactive imagination states that it will arc from the poles directly into me (and to boot I am going to be using a mylar sheet as an extra ground sheet).
Any thoughts?
Ta ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Handsome |
 Handsome World Chat Champion
 Posted: 21:28 - 28 Apr 2009 Post subject: |
Make sure you've got your cock in your hand as then you'll come/cum and go at the same time...
HTH...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
 Posted: 21:44 - 28 Apr 2009 Post subject: |
From reading about the consensus seems to be that if it is totally flat:
1) Do NOT be the highest thing around.
2) Do not be near the highest thing around.
3) Do not be near any pointed objects (metal or otherwise).
4) You are more likely to be effected by ground current than a direct strike so lying down is not helpful. Nor is standing with your feet apart.
5) Insulation does fuck-all. A free electrical arc just travelled through 300m of AIR. Rubber soles will do squat.
Practically, get in a dip, away from the bike or trees. Don't be in the tent with the poles up, it's a track to earth that is near you. Squat down. Keep your feet together.
Best bet to me sounds like putting on a poncho and hunkering down under it.
In case of a strike, perfor CPR. Lightning strike is DC, it causes cardiac arrest but NOT fibrullation. Rapidly applied CPR has a good chance of restarting the heart. A precordial thump may be all that is needed.
If there is a car or truck nearby, get in it. This will almost 100% protect you from lightning strike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Itchy |
 Itchy Super Spammer
 Posted: 22:22 - 28 Apr 2009 Post subject: |
Oh dear.... there doesn't seem to be much you can do......
*quietly files this under things to not think about*. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Howling TerrorOutOfOffice |
| colin1 |
 colin1 Captain Safety
 Posted: 00:32 - 29 Apr 2009 Post subject: |
| colin1 wrote: | I reckon the alloy poles will act as a lightning rod.
Electricity will choose the path of least resistance, so in your tent, the alloy pole will take the hit not you. They will also conduct electricity with little resistance, so wont generate much heat.
Its electricity going through something with resistance that generates heat.
Probably a good idea not to be too close to the tent pole though. |
Yeah, like within a couple of hundred yards. A lightning bolt hitting an alloy tent pole will pretty much vapourise it and set fire to the tent. The current will then track along the ground until it finds a low resistance track to earth.
If you are lying in the path of it, it'll pass right through you on its way. If said track passes via your heart, you're fucked. If you're standing with your feet together, you get track burns on your feet.
Here are a couple of "ground zero" lighting strike pictures. The only good policy is being nowhere near it. It turns sand to glass where it hits. It takes roughly 10,000V to arc through 1cm of air.
https://thegoat.backcountry.com/blog/files/2008/07/lightning-strike.jpg
https://i17.photobucket.com/albums/b59/jbodine/Misc/LightningStrike.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Phoenix |
 Phoenix Twisted Firestarter
| Peirre oBollox |
 Peirre oBollox Could Be A Chat Bot
| Itchy |
 Itchy Super Spammer
 Posted: 08:48 - 29 Apr 2009 Post subject: |
c'mon guys this isn't funny! ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| yen_powell |
| Itchy |
 Itchy Super Spammer
| Feasty |
 Feasty World Chat Champion
 Posted: 15:55 - 29 Apr 2009 Post subject: |
| stinkwheel wrote: | From reading about the consensus seems to be that if it is totally flat:
I never really understood this bit, okay I understand that it's not a good idea to be the highest thing around. So by standing next to something else that's the highest thing around means you're not, surely that's a good thing!? Of course just make sure if it gets struck you run around to the side NOT falling towards the ground!  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). Also now a Tiger 1050, easily best of the lot! |
| Itchy |
 Itchy Super Spammer
The last post was made 17 years, 184 days ago. Instead of replying here, would creating a new thread be more useful? |
