orange peel
Ibrahim
PostPosted: 16:48 - 28 Apr 2009    Post subject: orange peel Reply with quote
Hey, im not sure if this is the right place to post this thread. I started airbrushing a year ago, and recently got a hvlp gravity feed spray gun from DeVilbiss. After i design the motorbike piece and go to put the lacquer it gives an orange peel texture.
https://www.briansmodelcars.com/uploads/tutorials/30/orange-peel.jpg
I have tryed ways to prevent it like, increasing air pressure, playing with the fluid flow, gun distance/speed. If you got any other ideas please post up. Im going crazy with it, ive tested different ways on scrap car pieces before i do it on the bike but same result all the time. Evil or Very Mad
tutton
PostPosted: 21:56 - 28 Apr 2009    Post subject: Reply with quote
Wait for it to bake off then,
You need to use 1500 on a disc,
or 2000 wet and dry paper, use a flat surface like a block or DA, flat it all off till it starts looking matt, be careful of edges they burn through very easy, then work at it upwards starting at a harsh grade polish upwards.
ZRX61
Victor Meldrew
PostPosted: 22:30 - 28 Apr 2009    Post subject: Reply with quote
What he said..
tutton
PostPosted: 22:32 - 28 Apr 2009    Post subject: Reply with quote
Holy shit cakes
first time i think ever zrx61 has 100% agree'd with one of my posts.
ZRX61
Victor Meldrew
PostPosted: 22:44 - 28 Apr 2009    Post subject: Reply with quote
tutton wrote:
Holy shit cakes
You have occasional moments of clarity...
Ibrahim
PostPosted: 06:43 - 29 Apr 2009    Post subject: Reply with quote
nice, thanks. This will help covering it up, i was planning in preventing it all together. Ill try it again on a scrap car piece i airbrushed and update, thanks again folks!
ZRX61
Victor Meldrew
PostPosted: 01:22 - 30 Apr 2009    Post subject: Re: orange peel Reply with quote
Different speed reducers to tweek the mix
Ambient temp
Ibrahim
PostPosted: 11:10 - 30 Apr 2009    Post subject: Reply with quote
The temp in my garage is good, so it cant be that. I was thinking of thinning the lacquer but theres a label on the bottle "no thinner", so i scraped that idea. Im also going to start getting parts for designs from people to do and cant give them a finished piece with the lacquer looking like that. Im going to try and use a wet, soapy 1500 on a disk and see how it goes, ill try posting pics of end results.
tutton
PostPosted: 22:57 - 30 Apr 2009    Post subject: Reply with quote
Dont do a wet soapy 1500 disc it will clog in seconds!
where i used to work we used to polish new sprays using
1500 disc on DA till matt.
Trizact disc with water on da,
then start with the compounds.
ZRX61
Victor Meldrew
PostPosted: 06:51 - 01 May 2009    Post subject: Reply with quote
& what temp does is specify on the tech sheet?
Apparently you bought crap clearcoat..
Ibrahim wrote:
Im going to try and use a wet, soapy 1500 on a disk and see how it goes.
It will end in tears...
Ibrahim
PostPosted: 11:18 - 01 May 2009    Post subject: Reply with quote
eek, ok scrap that idea too. i wont even bother using a wet and soapy 1500.
Yeah i know, i asked the man for the best especially for auto parts and he gave me this. I told him i wanted a lacquer that i can mix with thinner so i can thin it as much as i want, he went on about how much better this is so like a doof i got it.
My idea is to sand with a wet soapy 1200, without the disc, I wont go too crazy on it. Then ill use a buffing compound and wax, applying them with a da buffer. What do you think?
thanks for the help, i appreciate it.
tutton
PostPosted: 13:08 - 01 May 2009    Post subject: Reply with quote
Ive always been taught to use the disc 1500 on the DA till matt as said, then use a 3m trizact disc which (iirc the grade these actually achieve is 3000) with water, then start on poishing, dont bodge it, will make it even worse than it already sounds like it is.
bonehead
PostPosted: 20:45 - 01 May 2009    Post subject: Reply with quote
The orange peel effect is usually caused by
1. Using the wrong mix of paints, eg cellulose primer with acrylic top coat, or maybe a acylic primer with a cellulose top coat.
Make sure you not mixing your paints.
2. Water. if you still have water residue from wet and drying and then apply the laquer/to coat it'll fuck up, degreese it, let it dry properlly the laquer/topcoat it.
Ibrahim
PostPosted: 21:11 - 01 May 2009    Post subject: Reply with quote
ok thanks for all the info. I am going to try my way and tuttons way on different scrap car pieces. Im going to get the compounds i need tomorrow and see which way works best.
i havent mixed the paints for the basecoat and i have left it to dry completely before putting the lacquer on, ive tryed alot of ways to prevent the orange peel but they dont work. Im just worried not to screw up when i spray the motorbike. Thanks, ill try sorting it out the soonest and updating.
ZRX61
Victor Meldrew
PostPosted: 23:22 - 01 May 2009    Post subject: Reply with quote
Nice theories.... both competely wrong.. Rolling Eyes
Orange peel is usually caused by tip to surface distance, temperature, wrong tip size or making a balls up with the air pressure or incorrect mixing/wrong reducer
The last post was made 17 years, 59 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 85.5 Kb
