carb problems
nuts
PostPosted: 14:16 - 30 Apr 2009    Post subject: carb problems Reply with quote
I have just got a Suzuki bandit 400 1991.All fuel pipes and choke cable and throttle cable have been disconnected..can you help. Confused
Chri
PostPosted: 15:35 - 30 Apr 2009    Post subject: Carbs :) Reply with quote
Hi m8, might sound daft but i had the same problem with my GS500, loads of pipes Shocked ,
I typed in (Suzuki GS500, carbs) on google images and found a diagram showing exactley how to fit it Very Happy , definatley worth a try Thumbs Up
Chri$
KevTM
PostPosted: 16:25 - 30 Apr 2009    Post subject: Reply with quote
To get the choke cable and the throttle cable on you ideally need the carbs off, the throttle cable is a pain in the ass to get on (until you find the technique).
The pipe at the bottom between the middle two carbs is the fuel inlet.
The pipe at the top between the middle two carbs is the breather.
The bracket at the top between the middle two carbs is for the throttle cable.
The bracket at the front of the carbs slightly to the left is for the choke cable.
I hope that makes sense, it's easier with a diagram or a photo.
The last post was made 17 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.33 Sec - Server Load: 2.16 - MySQL Queries: 15 - Page Size: 35.03 Kb
