| yuri2085 |
 yuri2085 World Chat Champion
| bikedemon99 |
 bikedemon99 Spanner Monkey
| yuri2085 |
| user |
 user Nova Slayer
| yuri2085 |
 Posted: 20:54 - 01 May 2009 Post subject: |
Ok thanks for your help will be on it tomorrow morning .
The only thing I am unclear about is the opening the break fluid resovoir master cylinder, this isnt the little clear filler box? How would I identify this and does it really need to be opened.
I think I will just use mucoff spray, a least the mucoff disc brake cleaner only has additional things to 'rehydrate the brake pad' -_- unless thats really worth buying another product for i wont bother.
Thanks again
Chris |
| Noxious89123 |
 Noxious89123 World Chat Champion
| user |
 user Nova Slayer
 Posted: 23:13 - 01 May 2009 Post subject: |
There's a few threads explaining how to do this in the workshop guides here which explain better than I can.
You will need to take the top off the resevoir, the front one will be attached to the brake lever/master cylender assembly, the back one is often tucked away somewhere, depending on the model of bike.
Good luck  |
| yuri2085 |
| Noxious89123 |
 Posted: 00:02 - 03 May 2009 Post subject: |
I used some proper brake cleaner and got a couple of small paint brushes from Wilco's for about 65p. Got them lovely and clean.
You can use a little copper grease on the backs of the brake pads, to stop them squealing. You can use a little silicone grease aroun the edges of the pistons to make them slide in and out easier. I used some silicone grease on the backs of the pads, because i didn't have any copper grease.
Don't use copper grease on the pistons though. I don't know what it'll do to the rubber seals, and it's also a rather viscous / coarse, so not great for lubrication. It's used more for putting on bolts to stop them seizing in things. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| ms51ves3 |
 ms51ves3 Super Spammer
| Noxious89123 |
 Posted: 17:56 - 04 May 2009 Post subject: |
Pah, stop being picky!
If you open a container of brake fluid, your meant to use it and then chuck it, because once the container is open it can absorb moisture and all that jazz.
If your just cleaning them up etc, I'd rather use a little silicone grease rather than open a container of brake fluid.
Same difference at the end of the day, both will do the job lovely. ____________________
| ms51ves3 |
The last post was made 17 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
