Helped by a kickstarter
kawashima
PostPosted: 15:41 - 03 May 2009    Post subject: Helped by a kickstarter Reply with quote
Today my W650's batterie was nearly flat and the cell motor didn't run at all. This was the first time I couldn't start with cell motor.
After kicking kick starter about 30 times, it started luckily.
I rode for an hour and tried again, cell ran but couldn't start it.
This time I could start with one kick easily.
I've thought kick starter of W650 is there only for retro image, but I was helped by it and changed my mind.
30 times kick start is fine but 30 times bump start isn't fine for me.
I think every motorcycle should attach both cell & kick starter IMO.
What do you think?
own:2020 Serow 250
Quote Me Happy
PostPosted: 15:57 - 03 May 2009    Post subject: Reply with quote
I think road bikes on the whole are fine with just electric start as generally you will be able to bump them and get to where you are going/home and sort the problem.
Off road bikes on the other hand should always have a kick start - it could be a long and tiring push back to civilisation through the mud if your battery packs up.
PostPosted: 15:58 - 03 May 2009    Post subject: Re: Helped by a kickstarter Reply with quote
What do you think?
I have four bikes and three of them have kick starters only. I do find them very useful, but when you've only got a kicker they can also be a huge pain. Take my MZ for example; the kickstart is short and on the left side of the bike. It is not held on with the usual splines but just has a plain steel dowel through it. This steel dowel regularly works itself loose and so you often end up playing kickstart russian roulette. If the bike doesn't start first kick then the dowel invariably works its way loose and you then can't start it at all until you've found a hammer to knock it back into place. Despite being a 300cc two stroke it also kicks back at you very fiercely and can hurt you. With the added disadvantage that the kick back always works the dowel loose again.
I don't have these troubles on my RDs but I do have a love hate relationship with the Kick starter. If you start it first or second kick then you look really cool. If you keep stabbing at the lever then you look like a chump. I suppose you can't have coolness without an element of risk though! Smile
Gawain
PostPosted: 16:00 - 03 May 2009    Post subject: Reply with quote
If its modern TCI ignition even with a kickstart it wont start as there wont be enough battery life to give a good spark... Maybe for marginal batteries but not for dead ones.
TheDonUK
PostPosted: 16:01 - 03 May 2009    Post subject: Reply with quote
How big are the mechanisms? practicle on a road sportsbike?,
If it dident change the ground clearance or adversely affect handling i would welcome a kickstart.
I ran out of petrol for the first time in a while last night, while trying to thumb a lift (hitching is almost extinct), and had to crank the starter for a while, i would have prefered to use a kickstart there.
Thats what you get for riding something designed from a racer Arrow
.Chris.
PostPosted: 16:06 - 03 May 2009    Post subject: Reply with quote
They're very handy. Obviously they look a bit out of place on a sports bike but I'm not quite sure why the manufacturers deleted them from naked bikes, as like you describe they can get you home if your battery dies.
Same goes for cars really, starting handles seem antiquated but they're actually quite useful. Handy for turning the engine when setting valve clearances too.
Chris
1985 Kawasaki Z550F
PostPosted: 16:07 - 03 May 2009    Post subject: Reply with quote
Its not really practical on a sportsbike as most would be damn hard to kick. Imagine trying to kickstart a TL1000S!
A 600 might work, but electric starters are so reliable these days anyway, and things like ECUs, injectors and fuel pumps need working batteries to get the engine started in the first place. You might have gotten away with a kicker on a 600cc carbed bike, but on a modern injected bike you've got no chance.
kawashima
PostPosted: 16:34 - 03 May 2009    Post subject: Reply with quote
It must not be easy to do a bump start on a off road!
I won't be able to start your bike Shocked
I was lucky. Neutral lamp was lighting slightly. If this was 1 month later, I might need re-charging.
I haven't had these troubles on cars. Maybe Cars can have big batteries than bikes?
Ouch. I didn't know that. Only carb bikes...The newer the more the bike relys on its batterie then!
own:2020 Serow 250
PostPosted: 17:57 - 03 May 2009    Post subject: Reply with quote
I would love a bike with a kickstart. I've just put a new battery on the CB500 and she's happy again, but it wouldn't have killed them to put one on, seeing as it is a commuter. Not everybody has the energy to run up and down with a bike trying to bump start it. I'm tempted by a W650 for that very reason.
McGee
O RLY?
PostPosted: 18:00 - 03 May 2009    Post subject: Reply with quote
I have for many years wanted a muscle bike with a kickstarter.
Just for the whole kicking it on and getting on.
I was thinking getting a retro Harley and making it into a cafe racer.
Its pronounced Jixxer!
ncrn
PostPosted: 19:54 - 03 May 2009    Post subject: Reply with quote
While I don't have any issues bump starting a bike, I find it can be a pain to do sometimes, especially if you are on a busy road or just in a really unfortunate position (at the bottom of a valley or something?).
I haven't had to bump my ER-5 yet, I'm thinking I might want to practice at some point as I've only bumped small bikes before.
Robby
Dirty Old Man
PostPosted: 20:55 - 03 May 2009    Post subject: Reply with quote
What's this electric start you all speak of? Sounds like something for ladies and homosexuals to amuse themselves with.
Suitor_Stu
PostPosted: 21:01 - 03 May 2009    Post subject: Reply with quote
As said, there's nothing cooler (in the biking world at least) than jumping back on your bike, giving it a kick with a wee handful of throttle just to make sure then hearing it explode back into life - much more satisfying than pressing a button which winds a weedy electric motor to do the work for you.
That said, they are a right pain in the proverbial if you have been stopped at a set of lights of a while and just as you snick it into first the bastard stalls on you. This leads to a hurried 'clutch in, duck-walk to the side of the road' move then coupled with the routine of trying to find neutral again (which when stationary on a bike with a grearbox designed in the early '50s is a task in it's self!) and hopefully getting it going in time to make it back into the stream of traffic before the lights change again!
I suppose it's easier to tell when the battery is getting low mind you - I know that if I start to sweat trying to kick then it needs a charge!
Stu
Chriss
PostPosted: 21:44 - 03 May 2009    Post subject: Reply with quote
You lot make me want to modify the DRZ to put a kicker on it now.
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Itchy
PostPosted: 22:03 - 03 May 2009    Post subject: Reply with quote
You can costs £140 in parts and a couple hours labour, it costs less if your DR has the engine cover which still has the hole for it.
My XT was retrofittable for a kicker for about £170 , but this was without the decomp mechanism which few people knew how to retrofit and those that did wanted lots of money for it, which meant that the kicker would invariably snap after a few uses.
Many people have horror stories with kickers though , for adventure riding , in Africa and South America off the beaten track , when they are crossing a rickety bridge and it stalls, press the magic button and you are done in about a second, kick starting a hot bike while on a single log bridge high above a river would be iffy. Peter has a story in Bury where to short cut 7 miles you cross a river by the remainants of a brdge which is just a 1 ft wide piece of concrete 20ft above the river.
binge
Emo Kiddy
PostPosted: 22:43 - 03 May 2009    Post subject: Reply with quote
My pit bike is Kick start only. And its running a thinking called an "Outer Rotor Kit". Rather than a full size flywheel.
It's like a mini fly wheel, with Mini coils inside it. It's designed to be lighter.
Down side of this is the interia weight is alot less, And it stalls pretty easy.
Picture yourself at a red light. Goes amber, You dont have quite enough revs, And you stall it.
You are then holding up all the traffic you just filtered past, While you either paddle to the side of the road, Or fold the kick start out, And give it a good boot. Problem is, It's usually pretty hard starting it when its JUST stalled. Not sure why. Its a 150cc Single horizontal 4t engine. So quite a little thumper and has a good bit of kick.
Would be so much easier to just pull the clutch in and give the starter a whirl. (if it had one)
There are Electric start Pit bike engines out there. But they are a pretty shit design. And in order to start them on the kick start, They need to be in neutral with the clutch out.
Ben
truslack
PostPosted: 23:29 - 03 May 2009    Post subject: Reply with quote
All 3 of my bikes are kickstart only - 2 of them on the left hand side. The 125 is easy to start, and one of the 500's is alright when cold, but my second 500 is a bastard to start all the time. It'll be treated to a new carb sometime though, should help a bit.
PostPosted: 23:35 - 03 May 2009    Post subject: Reply with quote
The TZR is very easy to start. Once warm I can hand start it too.
truslack
PostPosted: 23:39 - 03 May 2009    Post subject: Reply with quote
That's cause it's a toy bike. Laughing
PostPosted: 23:46 - 03 May 2009    Post subject: Reply with quote
It's just well engineered Wink
The last post was made 17 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 116.61 Kb
