Clutch Problem on Bandit 12
Marah
PostPosted: 10:50 - 05 May 2009    Post subject: Clutch Problem on Bandit 12 Reply with quote
Looking for potential cause of my clutch problem.
Basically it fails to disengage, ie clutch in change to 1st release and I am going no where, after about 5 mins it starts working fine and I am off.
Any ideas?
Thanks
Someone complimented me on my driving. They left a note on my windscreen, it said "Parking Fine" Very Happy
Old Bikes -1990 Yamaha DT50MX > 1988 Kawasaki KMX125 > 1991 Kawasaki KMX125 > 1981 Yamaha XS250SE > 2000 Suzuki Bandit 600 > 1999 Kawasaki ZX7R Ninja
Bike - 1999 Suzuki Bandit 1200
PostPosted: 11:00 - 05 May 2009    Post subject: Reply with quote
The clutch on the Bandit 12 is a hydraulic one, and pushes a shaft from under the front sprocket cover through the gearbox. Part of that shaft is exposed to rubbish from the chain. It could be a build up of that rubbish that is stopping the shaft from returning easily. That would be the first thing I would check. Also check the shaft is still straight.
It is also well worth cleaning up the system and bleeding it. Plenty of people rarely bother to bleed the clutch and the resulting fluid can cause issues (ie, can result in a solid residue that can block some of the small holes in banjo bolts, etc).
Marah
PostPosted: 11:20 - 05 May 2009    Post subject: Reply with quote
Will give that a go changed the brake fluid recently as it was non responsive. So high chance the clutch side has went the same way. Will get all the gunk cleared as well and fingers crossed that will be that.
Thumbs Up Very Happy
PostPosted: 11:46 - 05 May 2009    Post subject: Reply with quote
You can get rebuild kits for the clutch master cylinder (just did the one on my Bandit). Biggest problem is that there is a thin metal shield under the sprocket cover protecting the master cylinder, which is held on by 2 soft and easily damaged philips head bolts, which on mine were a pig to remove. I landed up cutting a deep slot in each one with a Dremel so I could put some reasonable force on them.
The last post was made 17 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 43.19 Kb
