RSV-R Steering Damper
JAMSXR
PostPosted: 09:38 - 05 May 2009    Post subject: RSV-R Steering Damper Reply with quote
Hi all,
Picked up my RSVR last week, so far I have been very impressed with the bike, the build quality is superior to any of the Jap bikes I have owned in the past.
The only problem I have come across so far is one with the Ohlins steering damper. Being the first bike I have owned with an adjustable steering damper I am not sure whether it’s a problem or not? The steering damper has about 1cm of vertical play (up and down movement), I can see the bolt that would require tightening if need be, but unfortunately it is a complete bitch to get to, and I don’t have the correct spanner to do the job unless I take the whole nose cone off. So before I take it down to the local bike mechanics, who would hopefully have a spanner that would do the job I just wanted to check that the steering damper should be secure to the bike, or whether that vertical movement is there for a reason which I don’t think it would be?
Thanks
J
lonner
PostPosted: 19:37 - 05 May 2009    Post subject: Reply with quote
hi
all the dampers ive come across are a good fit .
they have movement ie roll side to side as there on a ball joint.
but it sounds like you need it tightening up if you have 10mm of up & down play.
can you bend a ring spanner so you can get too it Thumbs Up he who dares rodders its all part of the fun Very Happy
good luck Thumbs Up
JAMSXR
PostPosted: 21:59 - 05 May 2009    Post subject: Reply with quote
Cheers.
The last post was made 17 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.07 - MySQL Queries: 13 - Page Size: 36.08 Kb
