Building my own PC
Eddie Hitler
PostPosted: 14:42 - 06 May 2009    Post subject: Building my own PC Reply with quote
Right..
Basic outline. I won't have any trouble building, installing and all the other odds and ends when it comes to building a PC. I was an I.T technician for a year when i was 16-18 years old. Also had no end of trouble with my own PC and other peoples. Laughing
Only problem is I havn't taken any interest in PC components since I left that job. So I have no idea what to buy!
I have a budget I would like to keep at (£250), although I can splurge a bit more if necessary.
I already have a monitor etc. I'm just looking at the base unit.
It will be used for gaming, although I'm not a "hardcore", I currently have an old Dell with a 256mb ATi and it seems to run everything I want at the moment, bar Oblivion. It runs, but not worth playing.
Any help is greatly appreciated. I really don't know where to start.
Scotsman37
PostPosted: 15:36 - 06 May 2009    Post subject: Reply with quote
Do you have the latest operating system - Windows Vista ?
If not, then best to buy a complete base system as it's cheaper that way rather than sometimes buying seperately when you don't have a legit copy of Windows Vista.
If you were in Glasgow I would suggest the following place to check out for a bargain;
World of Computers
https://www.e-woc.co.uk/
If not then;
Misco
https://www.misco.co.uk/applications/Category/category_tlc.asp?CatId=54
Overclockers
https://www.overclockers.co.uk/productlist.php?groupid=43&catid=1078
SCan
https://3xs.scan.co.uk/Category.asp?SystemMasterCategoryID=25
Eddie Hitler
PostPosted: 16:01 - 06 May 2009    Post subject: Reply with quote
I'd rather use XP home which I have a few legit copies for, and install that. But again I don't know if hardware would still be compatible etc.
The Artist
I suggest you use xp pro. Easy to get copy's of. Works fine etc. It means your budget pc will remain budget and not be slow and horrible. All hardware would still be compatible. If you want a copy of xp pro, pm me.
At the moment, go for Intel cpu/mobo dual core, or quad if you want to go for it but no real point. Even vista can't use 4 cores properly.
Graphics card, you can get a decent card for under £60 these days, refer to previous thread in this section.
Case, get something you like the look of that comes with a power supply. As long as you are not planning on getting expensive dual core ati graphics cards then there is no need for a massive power supply.
Ram is dirt cheap now so go for something well known like kingston or corsair as it won't cost that much more. 2gb should do for now. Can always buy another stick and add it in whenever you want.
Hard drive. Well the sweet spot with price is around 400gb at the moment. As in the price jump between 400 and 600 is disproportionate to the space you get. I got a 500gb hard drive for £39 from somewhere. You can get a 1tb for £70 delivered now.
Cooling, get a couple of decent akasa fans. Only a few quid each. One at the front, one at the side of the case.
Dvd rewriter, £15 unless you want a blu-ray type thing which are still expensive.
Make sure mobo has surround sound built in and get yourself a decent speaker set. I got a phillips 5.1 system off ebay for £30!
In the good old days it used to be AMD/Nvidia but seems to have changed. Intel have the lead on processors and ATI are producing stupidly fast graphics card for a lot less than Nvidia.
Scotsman37
PostPosted: 17:07 - 06 May 2009    Post subject: Reply with quote
It's true that XP or Pro version of it requires less powerfull hardware to run quickly, and so with current hardware available it would make your system appear to be very quick indeed. The only exception is that XP or XP Pro will eventually be left behind, as one day Microsoft will stop providing updates like what happened with Windows Me in the past.
Windows XP software updates was supposed to end this year except the deadline was extended due to an uproar by the public.
Windows Vista has a lot of nice features built-in like; partitioning a hard drive, better presented desktop along with Windows side bar, plus other neat features!
The only downfull with that is your base system's hardware needs to be fairly up to date to stay fast due to the fact that Windows Vista requires a minimum of 1Gb of RAM to make use of all the features and therefore you will need 2Gb+ RAM installed system for memory hungry games, while XP really requires 512Mb RAM to run at a proper speed without it lagging but with 1Gb it works very well with games.
Due to the fact XP alone was not designed for dual core and therefore you can download AMD's dual core software, but with Intel has already started leaving updates for earlier chipset software with no future support for Windows Vista. So you require the latest chipset to get support for Windows Vista.
The Artist
PostPosted: 17:16 - 06 May 2009    Post subject: Reply with quote
Exactly why xp would be better. They won't stop updates any time soon.
By the time they do, shitsta will have improved a lot and windows 7 will be out which is supposed to be a lot better.
teampots
PostPosted: 21:39 - 07 May 2009    Post subject: Reply with quote
https://www.cclonline.com/product-info.asp?product_id=21704&category_id=677&manufacturer_id=0&tid=ccl1020
that and a seperate graphics card would be ideal, throw your copy of xp on and your laughing
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
panrider_uk
PostPosted: 23:43 - 07 May 2009    Post subject: Reply with quote
I think updates will be available at least until until Windows 7 is released.
Resizing a partion you mean? A useful feature on latops and some PCs that come with their drives split 50/50 into c: and d:. HP had a utility called Dashboard on their Windows 3.x PCs that was similar to Sidebar - not really revolutionary. Much of the rest is gloss that could have been included in an XP service pack to be honest.
Agreed, but I'd go with a miniumum of 2Gb for Vista and 1Gb for XP these days.
I don't quite understand that. XP has always had multi-processor support.
If I was buying a PC and it came with Vista then I'd stick with Vista. As long as you have a modern pc with sufficient RAM then it is a bit better than XP.
If I were building a PC and had copies of XP lying around then I'd certainly put XP on it. Vista isn't that much of an improvement to make me go out and buy a copy of the OS.
I use Vista at home and XP Pro at work. They both work fine, they just differ slightly in the way they present themselves (M$ has moved everything around again as they always do).
Unless you want to put your PC into an Active Directory domain I don't see any benefit in choosing XP Pro over XP home.
Mark
Scotsman37
PostPosted: 00:12 - 08 May 2009    Post subject: Reply with quote
If you check AMD's website they have a dual core driver for Windows XP so as to balance the usage of their dual core processor more efficiently. Intel wa the preferred provider back in the days when Windows XP was the latest out, maybe they included it in their service xp updates except they brought out a lots & lots of updates.
The Artist
PostPosted: 00:51 - 08 May 2009    Post subject: Reply with quote
Have you got a link to this amd dual core driver for xp?
Thanks
Scotsman37
PostPosted: 01:44 - 08 May 2009    Post subject: Reply with quote
Here it is and other appropriate drivers too
https://support.amd.com/us/Pages/AMDSupportHub.aspx
Fnatic
PostPosted: 01:53 - 08 May 2009    Post subject: Reply with quote
It's easy.
Built my first at 14.
Eddie Hitler
PostPosted: 07:26 - 08 May 2009    Post subject: Reply with quote
Fnatic wrote:
It's easy.
Did you even read the OP. Laughing
UrbanRacer
PostPosted: 09:04 - 08 May 2009    Post subject: Reply with quote
World of Computers
utter sh!t, i wouldn't buy a cd case nevermind PC components from them.
SCAN or eBuyer is your best bet.
I did a rebuild about 18months ago with an Intel Quad Core CPU, 6gb of Ram, nVidia 8800 GFX Card, IP35 Pro motherboard and its still able to play all the recent games with the GFX options turned up.
The Artist
PostPosted: 14:42 - 08 May 2009    Post subject: Reply with quote
Where is the actual bit that says "multi core support for xp"
Scotsman37
PostPosted: 15:57 - 08 May 2009    Post subject: Reply with quote
Look, on that page click on the part where it says download processor drivers and it's listed within there known as dual core optomizer !!!! Rolling Eyes
Here's Microsoft's fix in regards to Windows XP in general running on multi core processor based systems.
https://support.microsoft.com/kb/896256
Eddie Hitler
PostPosted: 19:08 - 08 May 2009    Post subject: Reply with quote
I think i'm going to buy most of the components from eBuyer, i've had good experiences with them in the past so sticking with what i know.
So from the advice in this thread Intel is the best to go for, so whats a good mobo to start with?
Bare with me, you can tell im not up to speed at all with PC's. Laughing
The Artist
PostPosted: 20:12 - 08 May 2009    Post subject: Reply with quote
Motherboards are strange. Depends what you want out of it. I usually go with Asus as they don't fail. Proper well built boards and never had a problem. Sometimes slightly more expensive than others for the same features but rock solid.
Make sure you get one with enough ram slots for your needs and correct cpu socket etc
Scotsman37
PostPosted: 23:35 - 08 May 2009    Post subject: Reply with quote
I fully agree with that, as I have never had a failure except you do have to keep on the look out for BIOS updates for improved compatibility/stability !
Never had an Asus board fail on me they just keep on going...!
NSR Mick
PostPosted: 08:06 - 09 May 2009    Post subject: Reply with quote
Get a decent named mobo from the likes of Asus, Gigabyte etc.
Dont get a biostar, I've built 2 pc's recently with exactly the same spec except one has a Gigabyte board the other a Biostar and for some reason the Biostar seems laggy even with a dual core 2Ghz celeron 2gb ram and a ata 300 hdd running xp while the system with the Gigabyte board flies.
Theoutsider
PostPosted: 00:33 - 16 May 2009    Post subject: Reply with quote
Actually you can create partitions and format hard disk from the xp set up.if you know how.And by the way I don`t think microsoft will stop the updates any soon,because there are still a lot of desktops and laptops that are using xp.I think almost everybody is using xp.I am not using because is no point puting xp on a Acer 6920G.Maybe 75% of the planet are still using xp
Theoutsider
PostPosted: 00:34 - 16 May 2009    Post subject: Reply with quote
I`m only 17 but i built computers since i`m 12 lol Smile) ,and I have to say that Abit are very good,never go for a biostar they are utter shit
Scotsman37
PostPosted: 04:37 - 16 May 2009    Post subject: Reply with quote
Yes, but it's not user friendly for anybody just starting out getting to know about how to do these type of things as it should be, and that is why Vista is good foin that area because Microsoft incorprated it there to be accessed from the via the control panel for ease of use in a user friendly interface/tool.
The last post was made 17 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 124.02 Kb
