Brake pad thickness??
zaknafien
PostPosted: 05:16 - 14 Jul 2002    Post subject: Brake pad thickness?? Reply with quote
whats the recommended minimum breakpad thickness before they need changing?
Im sure mine are fucked but i cant get em off (already tore the head of one bolt trying to unscrew it Sad )
02 Firestorm.
zaknafien
PostPosted: 10:59 - 14 Jul 2002    Post subject: Reply with quote
Also anyone know when i can look at pads that will fit a 91RK to compare prices?
02 Firestorm.
air
PostPosted: 16:27 - 14 Jul 2002    Post subject: Reply with quote
Those depth lines that are on the pad are a guidline, if the surface of the pad reaches the surface of the depth lines, then its about time to change. At that point the brake lever will be pretty slack unless you've filled the reservoir anyway.
PostPosted: 19:13 - 14 Jul 2002    Post subject: Reply with quote
The lever should not get slack. Never let the fluid level drop low enough to allow air into the systems
Dan
PostPosted: 22:18 - 14 Jul 2002    Post subject: 1 Reply with quote
better to be safe than sorry u dont want it go to the metal cos it will reck ur brake disk costing mmore money
The last post was made 23 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 42.86 Kb
