rear suspension
Swim41
PostPosted: 21:20 - 07 May 2009    Post subject: rear suspension Reply with quote
Would anyone care to enlighten me as to how the rear suggestion settings affect the cornering of a bike?
Bike in question is an XJ600N, fitted with a basic adjustable rear shock. I do a lot of weekends away with the bike loaded up so ususally have the shock set pretty firm to counteract the extra weight, but recently I've been playing around with it. On the softer settings although the ride seems a little smoother, cornering at speed feels a lot less predictable and not very confidence inspiring.
Is this in my imagination or will adjusting the (no doubt) original shock on a 12 year old commuter bike make much odds to the cornering - and if so, how? Does firmer suspension equal tighter handling?
cheers
Yamaha XJ600N
PostPosted: 21:49 - 07 May 2009    Post subject: Re: rear suspension Reply with quote
cheers
Unfortunately suspension is an incredibly complex issue. Simply saying that firmer suspension equals tighter handling is extremely simplistic. Manufacturers have been battling for years to find the perfect balance between ride comfort and handling. I could write a hundred pages on it and still only have scratched the surface.
The best guide I've found to getting the suspension settings to suit an individual is here:
www.marjay.co.uk/setup.pdf
Smooth
PostPosted: 10:16 - 08 May 2009    Post subject: Reply with quote
In simple terms:
Set the sag to the correct amount
If you've got a combined compression/rebound adjuste, gradually increase damping and the back end will feel less wallowy. Increase until the back end feels too harsh and then back it off a bit.
It will take some trial and error, but it is worth it.
When I got my bike 'dialled-in' the handling was vastly better than beforehand. It amazes me how many people don't even consider setting up their suspension correctly.
TDM850
PostPosted: 10:42 - 08 May 2009    Post subject: Reply with quote
The harder the suspension the less it can follow bumps in the road and the less grip you will have. The softer the suspension the harder time the damping will have and the more the bike will wallow, and with conventional bikes the more the steering geometry will be badly affected by forces on the suspension.
Somewhere between the 2 ends will be right for you.
Swim41
PostPosted: 18:52 - 08 May 2009    Post subject: Reply with quote
Thanks. From what I've tried so far, setting for around 2/3 stiffness seems to be the best balance for faster riding. I'll do some experimenting and see what happens.
cheers
Ben
Yamaha XJ600N
The last post was made 17 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 45.5 Kb
