| yuri2085 |
 yuri2085 World Chat Champion
 Posted: 16:54 - 10 May 2009 Post subject: Still having a couple issues with my brakes. |
Ok I will try and break it down and mention the important things that have happened.
Frontleft caliper: Taken apart, cleaned visible areas of pistons and the rest of the caliper...replaced brake pads (was no pad at all left) + put on the anti squal plate business.
Front right caliper: Took off and wiped the visible area of pistons with them not pumped out, could not remove brake pads because I shredded the head of the pin that holds them in (It cant be undone, I will have to destroy the pin and dont have a replacement).
The pads are pretty worn aswell, but there is a little bit visible -_- (I will order a new pin and get some pads asap)
When the front left caliper was off, the wheel span amazingly; with old pads and new pads it was noticeably stiffer with front left attatched (but as in previous thread wasnt a big deal unless very cold with old pads + before clean).
Attempted to bed in the new pads, started pumping the brakes first and the fluid level actually rose, even though I spilled some while cleaning. If I stand there pumping constantly eventually it gets firmer and causes good braking; but after 3 seconds the braking is pathetic and if the lever is against the handlebars it can still be pushed along if you try hard.
(so didnt really get any real bedding in done..)
When I gave in and decided I will try again once I can clean the other caliper and replace the pads, I noticed the right hand disc was cold and the left disc slightly warm which implied the piston (on the right) is jammed? but why on earth would be be jammed so far from the disc that it causes no braking at all (the wheel freespins the same amount with right caliper on and off). But the reason I even looked at my brakes in the first place was because I assumed the front wheel should be freespinning more. (see previous thread for problems in the cold with them jamming)
Can anyone make sense of all of this? Thanks ^^
| st3v3 |
 st3v3 Super Spammer
| yuri2085 |
| yuri2085 |
| st3v3 |
 st3v3 Super Spammer
 Posted: 14:35 - 11 May 2009 Post subject: |
The replacing of seals isn't necessary unless the ones in question are damaged in some way.
I'd say re-bleed them and try again from scratch, if you do it correctly and there is still something wrong then I'd be getting it to a techy in the shop but it sounds like they just need sorting. Brakes aren't the easiest job I hate it.  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| yuri2085 |
| st3v3 |
 st3v3 Super Spammer
| yuri2085 |
The last post was made 17 years, 159 days ago. Instead of replying here, would creating a new thread be more useful? |
