Chain come off ahhhh
kingsknight
PostPosted: 12:48 - 11 May 2009    Post subject: Chain come off ahhhh Reply with quote
shit man, was doing 65 on the way home from a mates last night when the my back wheel locked up out of no where! looked down and the chain had come off!
Recovery guy fixed it within about 5mins and i was back on the road again. ordered a new chain set last night! did shit me up tho! thought my engine broke!
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
Finglonga
PostPosted: 13:10 - 11 May 2009    Post subject: Reply with quote
Weekly maintenance should have prevented it. When was the last time you checked the tension of it?
Andy Sez....
F.Y.Y.F.F.
Welshd1k
PostPosted: 13:17 - 11 May 2009    Post subject: Reply with quote
on a 125 :O that must have been slack for AGES hells i only adjusted the one on the ns every 2-3k
Charlie
PostPosted: 13:27 - 11 May 2009    Post subject: Reply with quote
My chain came off my city fly twice. Both times quite lucky as the back wheel didn't lock up. After much fiddling me and my Dad decided the cush drives had gone because the sprocket could wobble more than it should be able to.
Paulington
I check mine weekly, and it slacks off so quickly over a week it's silly. Part of my weekly wash and check procedure. Thumbs Up
2-3k? That's mad! How slack was it compared to what the manual said after that?
Charlie
PostPosted: 13:31 - 11 May 2009    Post subject: Reply with quote
if it is getting slack that quick paul you are probably due a new chain soon.
Welshd1k
PostPosted: 13:35 - 11 May 2009    Post subject: Reply with quote
slack after a week??? your chain is dead ...
do you lube it /dump the clutch alot ???
oh i bet when you wash it the preshure washer gets the chain ??
yeah every 2-3k i put a oring chain on it and ive just changed it after 11k miles . and tighten it up to 1" is up/down then after 2k ish its got say 2" so just pull it back .
hell's my mx50 did 9000 km's on a chain and that thign was razzled
Charlie
PostPosted: 13:41 - 11 May 2009    Post subject: Reply with quote
Dad's transalp did 50,000 miles on a chain... when he came to changing it he said they chain was fine, it was more that the front sprocket was shagged. The only time it got adjusted was when the back wheel had to come off for what ever reason (mainly new tyres) .
DID gold x-ring chain with a scotoiler and standard honda sprockets.
Paulington
PostPosted: 13:53 - 11 May 2009    Post subject: Reply with quote
Lube it once a week with Silkolene Chain Lube, what I use on my kart, top stuff. Thumbs Up
No clutch dumping, feed in nice and slow.
Washed by hand! Wash and wax! When I do clean it with the pressure washer (very rarely!) I dodge the chain.
Yeah, def. due a new chain soon, we shall see when! Laughing
Welshd1k
PostPosted: 13:55 - 11 May 2009    Post subject: Reply with quote
or just be a cheap skate like i was with my aprilia and keep cutting links out of it Razz
map
Mr Calendar
PostPosted: 13:59 - 11 May 2009    Post subject: Reply with quote
Confused what is this chain and lube and tension that you speak off Rolling Eyes
I know little of these strange words as I've been shafted for years Wink
On-topic, lucky not to break and engine casing with a chain whipping around. Maintenance is certainly best for preventing expensive accidents.
Paulington
PostPosted: 14:05 - 11 May 2009    Post subject: Reply with quote
Nah I think I can avoid that! Hahaha, will have to have a look for some RS50 chains now..
Welshd1k
PostPosted: 14:26 - 11 May 2009    Post subject: Reply with quote
£30 for a chain but change the sprockets at the same time looking at £40-50 for chain and sprockets
Paulington
PostPosted: 14:29 - 11 May 2009    Post subject: Reply with quote
Yeah just had a look around, that's fine. (: Thanks. Thumbs Up
Welshd1k
PostPosted: 14:30 - 11 May 2009    Post subject: Reply with quote
with your super duper motor get atleast a 14tooth front possibly a 15
Paulington
PostPosted: 14:51 - 11 May 2009    Post subject: Reply with quote
May change then, it's on a 13:41 at the moment I believe final drive. Thumbs Up
Thanks. Thumbs Up I may be able to put a tooth on the front like you said.
kingsknight
PostPosted: 16:21 - 11 May 2009    Post subject: Reply with quote
Yep i do weekly maintenance checks and the tension was fine its the sprockets which are really shagged! Iv got a chain and sprockets set on its way to me now!
The chain was dry i dont think i had oiled it in the last month or so but i wouldnt think that would make it come off would it?
Eddie Hitler
PostPosted: 17:08 - 11 May 2009    Post subject: Reply with quote
Err yea, that just shows your poor maintenance, its no surprise your chain came flying off.
kingsknight
PostPosted: 17:25 - 11 May 2009    Post subject: Reply with quote
i oil my chain once a month or every 500miles depending on which comes 1st!
Im pretty tight on my maintenance as i enjoy working on my bike! Just didnt notice how dry it was!
The Original Muzza
PostPosted: 17:47 - 11 May 2009    Post subject: Reply with quote
I'm pretty lax when it comes to chain maintenance. Lube it every 500 miles or so, proper clean and lube every 1000 less if it's been left for a while and only check the slack once in a blue moon.
Needless to say I paid for it, the chain came off my marauder when I was about to leave uni. Rather than call someone out, I stuck it back on like you would a pushbike chain when you were little and rode home. The adjuster was stuck fast and the socket wouldn't turn it. Called the garage from home and they said it would be £40 to come collect it, so I rode it in with slack chain. Looking back on it, it was a retarded and dangerous thing to do, but nothing happened so Thumbs Up
blutonium92
PostPosted: 18:55 - 11 May 2009    Post subject: Reply with quote
The RS50 i used to own chain was normally the right tension for about 20mins after tightening then it would go slack and flap off the swing arm >< ,
and no it wasnt a fault with the sprockets, swingarm, lock nuts or nything.. it was just plain shite.
Maybe a realy dodgy chain though?
.Chris.
PostPosted: 19:54 - 11 May 2009    Post subject: Reply with quote
The chain on my CD250 seems to go from being correctly tensioned to pretty slack in about 250 miles. I replaced it and the sprockets about a year (5000 miles) ago, but with the cheapest one I could find. Won't be making that mistake again. That said I'm not exactly religious about chain maintenance.
Chris
1985 Kawasaki Z550F
Seb
PostPosted: 20:32 - 11 May 2009    Post subject: Reply with quote
Getting a good chain makes a huge huge difference, when I got my ZZR the dealer put a fresh chain and sprockets on, a couple of months down the line and I was having to adjust the thing twice a week no matter what I tried on it to keep it in good shape. In the end I got a new did chain and sprockets which promptly did ~12000 miles with barely a handful of adjustments. With the way I rode that thing it'd have probably outlasted the rest of the bike with a scottoiler Laughing
2010 Triumph 1050 Sprint ST
Eddie Hitler
PostPosted: 00:57 - 12 May 2009    Post subject: Reply with quote
Lucky the chain didn't catch anywhere Luke. Shocked
Would hate to think how hard the front came down aswell.
The last post was made 16 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 131.13 Kb
