1997 GSXR600 SRAD Problem
Davie_G71
PostPosted: 15:00 - 11 May 2009    Post subject: 1997 GSXR600 SRAD Problem Reply with quote
Hello all,
As i pulled away from the petrol station after a run of about 20 miles at speeds between 50 and 100 i noticed a knocking that can be felt all through the bike, more like a clunk.
Symptoms:
1st gear, set revs to pull away, no knocking.
Let clutch out and start to pull away, a loud initial clunk and loads of smaller ones, not as loud.
2nd gear, let clutch out an accelerate, same thing, only not as loud.
This dissapears the higher i go in the range, or maybe it's happening but i can't feel / hear it as much.
I odn't think it's big ends as this would be evdent on just revving the engine, i'm thinking more gearbox / output shaft that sort of area.
The chain ans sprokets are worn and needing changing, i just hope i haven't broken anything big.
Any help greatly appreciated.
Davie
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
PostPosted: 15:06 - 11 May 2009    Post subject: Reply with quote
Sounds like you've folded the teeth over on the front sprocket. If it was just in 2nd gear I'd say your gear dogs were knackered as they ahve a habit of going in 2nd.
Davie_G71
PostPosted: 15:12 - 11 May 2009    Post subject: Reply with quote
Front sprocket looked ok last time i checked, but i'll check again.
PostPosted: 15:32 - 11 May 2009    Post subject: Reply with quote
If it's ok you're gonna have to provide more acurate info. Firstly, check the chain. Does it have any tight-spots or is it adjusted too tight? This will produce a 'crunching' sound when you ride.
lonner
PostPosted: 15:40 - 11 May 2009    Post subject: Reply with quote
it may have come lose so check the c & s first and see what you find.
Davie_G71
PostPosted: 15:44 - 11 May 2009    Post subject: Reply with quote
OK,
Chain has excessive play and i only have about 3 adjuster marks left on the swingarm, there are no tight spots that i can see.
I cleaned and lubed the chain yesterday, it seems ok if worn.
I'll get both checked asap.
theshmoo
Bottomless Pit
PostPosted: 15:45 - 11 May 2009    Post subject: Reply with quote
Bring it round to my place tonight mate
CBR 1100 blackbird.
Davie_G71
PostPosted: 15:52 - 11 May 2009    Post subject: Reply with quote
Your house, or your garage?
BanditsHigh
Worse than a woman
PostPosted: 18:08 - 11 May 2009    Post subject: Reply with quote
His house ... garage isn't ready yet ... I'll pop up as well.
Have you checked the sprocket bearing?
Davie_G71
PostPosted: 20:46 - 11 May 2009    Post subject: Reply with quote
Just back from Shmoo's where him and barry pronounced my chain and sprocket dead.
I'm OK with that, hopefully that's it and not something more sinister.
BanditsHigh
Worse than a woman
PostPosted: 20:59 - 11 May 2009    Post subject: Reply with quote
Oh so now you're questioning our mechanical knowledge ... I'll have my paddock stands back then ... and who's going to fit your chain and sprockets now Thinking
Davie_G71
PostPosted: 10:30 - 12 May 2009    Post subject: Reply with quote
You're paddock stands have now been donated to my garage, not a lot some back out if it when they get in there.
The last post was made 17 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 71.93 Kb
