Honda gearbox fault
moley
PostPosted: 20:05 - 11 May 2009    Post subject: Honda gearbox fault Reply with quote
Help needed please, 07CBF600 with 4,000 miles. When down shifting through the gears especially third to first it seems to make a slight squealing noise and also sticking. The problem has been looked at by the local Honda dealership as it is still under warranty, they have road tested and greased the gear selecter but are saying their is not a problem with the gearbox. The noise seems to be coming from the shaft that goes from the gear selecter pedal to the gearbox. It was serviced approx 1,000 miles ago and the chain tension is correct and also the chain is lubricated well. Any advice would be greatly appreciated as I desperately want this problem to be resolved.
geordiecbrblo...
PostPosted: 20:57 - 11 May 2009    Post subject: Reply with quote
If you're not happy then I'd suggest one or both of the following:
1) Get them to put in writing that there isn't a problem with it - incase it goes pop after the warrenty expires.
2) Get a second opinion.
Good luck Smile
The last post was made 17 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.2 - MySQL Queries: 13 - Page Size: 31.2 Kb
