Fairing Repairs
Thom
PostPosted: 15:33 - 11 May 2009    Post subject: Fairing Repairs Reply with quote
right! Well i've gone and damaged my main fairing on the Divvy. on the right hand side i've managed to split it downwards for about 6-8inches. i reckon this has happened because i lost a rubber well not so improvised a bodge with a normal nut and bolt to hold it in place.
Once i find a new well nut and bolt i plan to repair the fairing.
I have some experience of using plastex but i'm curious as to know which will be the better alternative for 'bridging the gap'.
I dont need to fill anything, simply make the split 'mate' properly again, its a nice clean break. so im thinking fibreglass on the underside may be a better option than plastex, any advice?
puremagic72
PostPosted: 16:09 - 11 May 2009    Post subject: Reply with quote
As you said, bit of wire mesh and p40 fibre glass from Halfrauds will do it, its what i did to my Front hugger.
But as for the front, i would open it up slightly (dremell) as you cant fill a " perfect crack", then fill it with p38 again from Halfrauds!
But then you would have to spray the panel (which i dont think you would want to do as you have said!)
Baz
Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
PostPosted: 16:18 - 11 May 2009    Post subject: Reply with quote
I favour "stitching" the inside of the crack using a hot soldering iron then putting a large splat of epoxy resin over the top of that.
Actually, that's not true. I favour epoxying and pop rivetting a piece of aluminium sheet across the inside of the crack which utterly prevents it opening up again. All that shows on the outside are the heads of the pop rivetts.
If the crack doesn't terminate at the hole, it is sometimes worth drilling a small hole at the "point" of the crack to stop it spreading further.
I once repaired an extensively smashed to bits fairing by gluing and rivetting copper sheet to the outside of it. Certainly a "different" look.
https://i48.photobucket.com/albums/f216/stinkwheel/fairing.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/gpzrat.jpg
Thom
PostPosted: 16:30 - 11 May 2009    Post subject: Reply with quote
well impressed with that gpz stinkwheel although the only reaosn i plan to repair the divvy is to maintain its resale value Razz
I think i'll try the stitching method and then epoxy over the top of it. luckily its hard to see into the fairing from any direction so i can plead ignorance if anyone asks if it's been repaired Very Happy
sickpup
Old Timer
PostPosted: 18:28 - 11 May 2009    Post subject: Reply with quote
Stock answer is Plastech.
Scotsman37
PostPosted: 20:14 - 11 May 2009    Post subject: Reply with quote
For cracked fairing, I remember seeing this neat way of repairing it on the inside part, but not the side exposed to view.
Get an appropriate sized nibbed soldering iron, where the the crack is and follow the the length of the crack by creating a very shallow channel. Now, melt some black plastic coat hanger along that channel, and lastly gently spread the freshly melted plastic over that shallow channel. This is supposed to give you a much stronger bond to prevent future cracking. On the exposed side the appropriate stuff as mentioned by another to clearly seal the exposed side of the fairing.
However, do not keep the soldering iron in one place for to long as not to distort exposed side of the fairing.
I think stinkwheel has been watching one to many Madmax movies! Laughing
PostPosted: 21:17 - 11 May 2009    Post subject: Reply with quote
I did. Bought it for £800. Rode it for three years. Put 30k miles on it. Had it crashed by a mate. Sold it for £360. Those are the photos I uploaded to ebay when I sold it.
The last post was made 17 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.34 - MySQL Queries: 13 - Page Size: 55.16 Kb
