| Adrian89 |
 Adrian89 Nova Slayer
 Posted: 21:01 - 11 May 2009 Post subject: clutch stuck on, is this a silly idea? |
Right I picked this beast up on friday for the pricey sum of £200 (if you can call a 400 a beast?) its been sat for a while (around a year maybe?) and the clutch is stuck on.
Im taking the carbs off anyway so there wont be any petrol to spill/flood, and Im guna give her a full service etc
https://i195.photobucket.com/albums/z115/adrianwest1989/My%20bike/my%20cbr/08052009060.jpg
I know its a wet clutch, and Im assuming its dried up over time (oil been forced out from between clutch plates) as the bikes been stood with all the oil angled towards the other side of the engine.
Would laying the bike carefully on the clutch side to let the oil soak it for a day or two with the clutch lever pulled in be a bad idea?
I guess I'd have to reposition brake fluid reservoirs etc to prevent leakages.
What do you think?
Thanks |
| Adrian89 |
| G |
 G The Voice of Reason
| stinkwheel |
 Posted: 21:10 - 11 May 2009 Post subject: |
What manner of beast?
Aye, clutch plates will often stick together.
They'll often shock loose if the engine runs by repeatedly engaging first gear with the clutch pulled in and the rear brake on (it'll keep stalling mind).
Another option is to simply strip the clutch while you have the oil drained. A genuine honda clutch cover gasket is £7.50.
Cutches are easy to strip once the cover is off. You undo 5 bolts with springs under, remove the top plate and slide the clutch plates out. Seperate them, oil them, re-install them and do it all up again with a new gasket. Half hour job requiring an 8mm and a 10mm socket.
The worst bit is scraping all the old gasket off the surface of the cover which will take another half hour and requires a stanley knife blade and a little patience.
Lying it on its side is a bad idea, the engine might fluid lock. Standing it upright and turning it over occasionally (which will cover at least 50% of the clutch in oil) isn't a bad idea. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Adrian89 |
 Posted: 21:13 - 11 May 2009 Post subject: |
Thanks for the response, I have 2 spare engines (one knackered but clutch is good), hopefully I wont have to change the clutch and the one thats in there will work, sticking the bike on a paddock stand and leaving it running is a much simpler way then laying it on its side!
Haha I thought of that then strangely forgot...
Il leave the clutch lever cable tied back a bit as well, that should help
Thanks  |
 ..... Quote Me Happy
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 21:33 - 11 May 2009 Post subject: |
For 200 quid I'd be mighty happy with that!  ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| Adrian89 |
The last post was made 17 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
