Speedos
spankydean
PostPosted: 13:20 - 30 May 2004    Post subject: Speedos Reply with quote
Icfbgwdg
Mr Pants!
I Karma
PostPosted: 13:29 - 30 May 2004    Post subject: Reply with quote
Not too sure how the speedo works on a bike, can not the tyre pressures being low cause an inaccuracy as the wheel diameter will be less?
I think it is a good question, also, they are always inaccurate by over reading the speed. Which is good as we would be getting done for speeding everywhere otherwise.
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
PostPosted: 13:35 - 30 May 2004    Post subject: Reply with quote
By law speedometers need to be accurate to within 5 miles an hour, but they are not allowed to underread, IE you aren't allowed for it to say you are doing 40 when in fact you are doing 45.
However... Over 70mph there isn't any point in them being accurate because you aren't supposed to go faster than that!
Generally speaking Japanese bikes' speedos begin to overread significantly over 70mph. This is often worse on a lot of italian bikes too (RS125s Mitos etc etc). This could be a sort of added safeguard to stop loads of "Mad bikers" from being caught speeding. I reckon though that its just that the manufacturers don't have any need to make the speedometers accurate above 70. Also, they only reallyt have to obey the law when new because an MOT test doesn't test the accuracy of the speedo, so some might possibly deteriorate.
Basically, don't get stressed when people say that bikes speedo's are innacurate because they generally are only over 70mph!
HTH Smile
PostPosted: 13:39 - 30 May 2004    Post subject: Reply with quote
Oh and tyre pressures won't make a difference as they don't make a significant change to the diameter of the wheel.
Also a lot of modern speedos are run from the front sprocket anyway. These speedos become inaccurate when the bike is downgeared. Smile
1cyl
PostPosted: 14:14 - 30 May 2004    Post subject: Reply with quote
I've wondered about this for a long while, there must be an accurate way of measuring speed on your bike, my speedo is mechanical, running off the front wheel. this is supposed to be the most in accurate but simple design, i think some of the bikes with digital speedo's are meant to give much more accurate readings all the way through the range.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Mr Pants!
I Karma
PostPosted: 14:22 - 30 May 2004    Post subject: Reply with quote
I have a Road Angel in my car which tells you your speed via GPS, I believe that is accurate if you continue at a constant speed over a given time.
PostPosted: 14:36 - 30 May 2004    Post subject: Reply with quote
GPS's are only accurate if you're not going up or down hill, because they measure speed in two dimensions, and don't take into account for vertical movement! Smile
Stew
If it's good enough for top race teams...
PostPosted: 14:42 - 30 May 2004    Post subject: Reply with quote
MarJay wrote:
Generally speaking Japanese bikes' speedos begin to underread significantly over 70mph. This is often worse on a lot of italian bikes too (RS125s Mitos etc etc). This could be a sort of added safeguard to stop loads of "Mad bikers" from being caught speeding.
Surely you mean over-read above 70mph? Razz It is illegal for a speedo to under read as you correctly mentioned.
My bike doesn't seem to bad indicated 160mph came out to be 151.1mph, of course it doesnt mean that the speed recording device at Elvington was 100% accurate (although it should really be more accurate than a bike speedo).
It has been said that most 125 have very highly tuned speedos Laughing just to allow mito/rs/nsr owners reach their claimed 120/115/110mph.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
jimbo
PostPosted: 15:15 - 30 May 2004    Post subject: Reply with quote
I read up on this a while ago. The EU directive covering speedometer accuracy is 75/443/EEC.
Here it is:
Section 4.3 Accuracy
"the following relationship between the speed indicated on
the dial of the speedometer (V1) and the true speed (V2):
0 ≤ V1−V2 ≤ (V2/10) + 4km/h
This means the speedo reading shall never read less than the true speed of the vehicle.
The indicated speed can be a maximum of 10% + 4km/h (2.5mph) above the true speed. The design engineer would probably aim for an error of about +5%, purely for simplicity in defining manufacturing tolerances.
Tests are made at 40, 80 and 120km/h. there is no stated requirement for testing above 120 (75mph), so accuracy is not guaranteed above these speeds.
Mechanical speedos usually use a magnetic drag-cup system, which will certainly be non-linear and accuracy would decrease at higher speeds.
A digital speedo should be linear across its entire range, so the error would be constant at any speed. Karma
From reading the directive it appears that the speedo can under read as much as it likes above 120km/h
PostPosted: 15:45 - 30 May 2004    Post subject: Reply with quote
Not sure if the European regulations have superceeded the UK rules, but the UK limit was they were allowed to over read by 10%, but not under read (slightly stricter than the EU rule that Jimbo quotes).
Speedos are inaccurate for numerous reasons. Tyre wear (on a bike tyre that is probably 1~2% between new and old)), tyre make (maybe another 3% from one make to another), tyre inflation (could be loads), speed (tyres increase in size with speed) and even the age of the speedo with mechanical ones (they rely on magnets which are likely to loose some of their strength over the years).
My 1200 Bandit (mechanical speedo driven from the front wheel) was indicating around 155mph when it was actually doing 136.5mph.
It is difficult to accuratly measure speed. GPS devices measure the speed on the ground, so take no account of hills. Speedos drive from the wheels / sprockets / gearbox are prone to all the problems listed above. Laser / radar only measures closing speed.
Dr Nick
PostPosted: 16:26 - 30 May 2004    Post subject: Reply with quote
Smaller inferior bikes run their speedos off the front wheel as they only have 1 disc, most bikes run them off of the front sprocket.
is that it
PostPosted: 16:48 - 30 May 2004    Post subject: Reply with quote
Plenty of bikes use speedos run from the front wheel but have twin disks. Speedods driven by the gearbox using electronics are lighter and cheaper.
Frost
PostPosted: 17:28 - 30 May 2004    Post subject: Reply with quote
The only truly acurate way to measure speed is through a device similar to an optical mouse, which when pointed at the ground measures changes in the surface below to calculate your exact speed.
Due to cost and practicality such things could only be used to calibrate a speedo.
Calibration does improve speedo acuracy, but speedos are normally only calibrated to be acurate up to 70mph, with the possible exception of police bikes.
So far as i know they only bike you can buy with a truly acurate speedo is the RSV mille which is acurate to within 1mph all the way up to 160mph
jimbo
PostPosted: 23:55 - 30 May 2004    Post subject: Reply with quote
Yes, this EU directive is binding on member states.
Using a GPS is a very accurate way of checking a speedo. Civil GPS has a worst-case position error of 100m or so, but speed is calculated using distance derivative, signal Doppler shift, or both, so the position error is reduced. Speed error on my GPS is quoted as 0.1km/h but realistically about 0.5km/h, still far better resolution than a mechanical bike speedo.
About 2km in a straight line is enough to get sufficient points to calculate speed accurately. It's not too hard to find a straight flat piece of road long enough!
If the average gradient of the road is 1/10 then the error over 1km is less than 0.5% = 0.75 km/h at 150km/h = not much.
In total GPS should get within 2km/h of true speed over land. Karma
Mr C
PostPosted: 00:30 - 31 May 2004    Post subject: Reply with quote
indeed they do
all the way to 198mph Wink
187.3bhp = 201mph
PostPosted: 11:33 - 31 May 2004    Post subject: Reply with quote
Watch what you are saying about bikes with mechanically driven speedos! Evil or Very Mad
The last post was made 21 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 96.79 Kb
