| Kickstart |
 Kickstart The Oracle
 Posted: 12:58 - 12 May 2009 Post subject: Vista Recovery |
Neighbour has an HP laptop on which the hard disk has just gone phut.
Replaced the hard disk and the recovery disks refuse to install. My guess is that they are keyed to some internal components, including the (now replaced) hard disk.
Short of buying a copy of Vista (silly money for something they have already paid for), any suggestions? There is a Vista licence key so we should be able to install from some generic Vista install disks.
| map |
 map Mr Calendar
 Posted: 13:03 - 12 May 2009 Post subject: |
What flavour of Vista?
There's so many I loose track.
I'm guessing on laptop Vista home? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Kickstart |
| Scotsman37 |
 Scotsman37 World Chat Champion
| Kickstart |
 Posted: 15:56 - 12 May 2009 Post subject: |
HP don't seem to admit to selling replacement installation disks as the machine is an ancient 15 months old now. Tried and the option is not on their site for this model.
Might need a replacement disk, but noway is it worth splashing out £130 for a replacement Vista CD.
Pile of cack. Poxy hdd life and recovery disks that refuse to work.
| Scotsman37 |
| Kickstart |
 Posted: 16:08 - 12 May 2009 Post subject: |
| Scotsman37 |
| Kickstart |
| JonB |
 JonB Afraid of Mileage
 Posted: 16:50 - 12 May 2009 Post subject: |
Download Home Premium on a torrent, I found the 32bit version for you https://torrents.thepiratebay.org/4882730/Windows_Vista_SP2_(32-Bit)_RTM_Retail_DVD_MSDN_REZMAN1984.4882730.TPB.torrent
Then just use the appropropriate key on the HP machine.
Or, you could just download the Windows 7 Release Candidate which is as good as final and you get a key when you download and it doesn't expire until July 2010, but then obviously you will have to pay for a copy of Windows 7.
For what it's worth Windows 7 is very good. Runs a lot quicker than Vista.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| Kickstart |
| JonB |
 Posted: 16:54 - 12 May 2009 Post subject: |
Windows 7 has an "XP mode" that can be downloaded for it.  ____________________ Be careful whose advice you buy, but, be patient with those who supply it. Advice is a form of nostalgia, dispensing it is a way of fishing the past from the disposal, wiping it off, painting over the ugly parts and recycling it for more than it?s worth. |
| bEN_ |
 bEN_ World Chat Champion
 Posted: 21:18 - 12 May 2009 Post subject: |
The reason the manufacturers don't give out the discs anymore is because they now say it's 'your' responsibility to create your own recovery/backup disc so will charge you £40+ for one off them ( Packard bell charge £55! ) , which still isn't bad for a legit OS really.
can i ask where he bought it from?
if he purchased it from either Dixons, Pc world or Currys then if the hdd failed and it's still within warrenty you get the recovery cd free
edit: just checked you said 15 months old
some HP/Compaq laptops will have 2 year warrenty because of 'known' issues ____________________ 2010 Ducati 848 Dark
Lamp Post Enthusiast |
| JonB |
| Kickstart |
 Posted: 21:56 - 12 May 2009 Post subject: |
The recovery disks were created. They bought 3 laptops at the same time and I have all 3 sets here. They all say that they cannot be used to repair that machine. My guess is that when you create the recovery disks they record the serial numbers of various components and refuse to recover if they have changed. And suspect one of those components is the hard disk.
Think they bought them from PC World.
| bEN_ |
 Posted: 22:05 - 12 May 2009 Post subject: |
Thats right, you may have to do a HP 'tattoo' with it
if it's like the packard bell one it's all done in cmd and can be a nightmare  ____________________ 2010 Ducati 848 Dark
| Kickstart |
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
 Posted: 00:30 - 13 May 2009 Post subject: |
Keith, are you just doing a straight forward re-install of the OS?
If so then it should simply be a case of install off the disc you downloaded, shove the license key they have into it and then phone M$ to confirm activation as it will probably ask you to do so. As you rightly point out "core hardware" has changed, although you may get away with an HDD swap, it seems hit or miss. Drivers, as you probably already know, are HERE.
I'm not entirely sure what bENN is talking about, done quite a lot of ground up rebuilds on mainstream notebooks and never found one that required prompt level entries to sort out. The only real problem was with an old Acer system and a reinstall from XP pro original media, had to burn a slipstream disk with SATA drivers on it as there's no floppy to preinstall the drivers from. Well, that and my recent battle with another Acer over BIOS passwords
For future reference, if you're ever caught short and need an OS at very short notice then you've got my mobile number. I've got pretty much everything here. ____________________ I'm immortal. Well, so far. |
| Scotsman37 |
| Seb |
 Seb World Chat Champion
| Kickstart |
 Posted: 11:35 - 13 May 2009 Post subject: |
| Tarmacsurfer wrote: | Keith, are you just doing a straight forward re-install of the OS? |
Yep. Install onto a new hard drive
| Tarmacsurfer wrote: | If so then it should simply be a case of install off the disc you downloaded, shove the license key they have into it and then phone M$ to confirm activation as it will probably ask you to do so. |
That is the hope, but the download is taking ages. Doubt it will be finished today or tomorrow.
| Tarmacsurfer wrote: | For future reference, if you're ever caught short and need an OS at very short notice then you've got my mobile number. I've got pretty much everything here. |
Thanks for the offer.
| Scotsman37 wrote: | Did they note on each disk which laptop it was created from or not? Then it's a trial & error find which one matches the appropriate laptop |
They did but we have tried all 3 and none of them are of any use.
| Scotsman37 wrote: | The hard drive doesn't matter (size/make) as they do accept they can fail and that's why you create the recovery disk(s) or buy a set from HP in case of hard drive failure or a severe virus infection. |
I wish. Seems the recovery disks are of no use except as coasters should you change the hard drive.
| Scotsman37 wrote: | If there is a serial check done by the recovery disk then it must be stored in a particular eprom on the motherboard that stores the information to match it up, because even in a factory you have to replace the hard drive if it fails the run-in tests! |
Not really. The serial number of components are easily found. No reason that when you create the recovery disks it cannot note these serial numbers on the disks it creates.
| Seb wrote: | Download an OEM Vista DVD (If your near Plymouth I'll give you one), doesn't matter which version as any OEM release can be used with any OEM key*, you can reinstall a Vista Ultimate key with a Vista Home Basic DVD with no issues whatsoever. Just install away with the key on the bottom of your machine. |
Are the disks the same? I can get access to one of the hi spec vista install disks, and if that would install as Home Premium with the relevant key then that would make life easy.
| Seb |
| Kickstart |
| Jamrock |
 Jamrock Nitrous Nuisance
 Posted: 13:37 - 13 May 2009 Post subject: |
When I worked at a Computer Repair shop we dealt with a lot of HPs, half of the time customers would try and use the recovery thing just for it to bluescreen pointing towards faulty motherboard drivers. I think HP just pump them out with every model and then have huge grins when people phone up asking to pay for them to repair it.
We stuck to the plan of doing a format reinstall with the OS of the sticker on the bottom, then downloading all the drivers manually. It's usually better that way because it doesn't come with all the bloatware as well. Install some DVD codecs and presto, back to normal!  |
| Scotsman37 |
The last post was made 17 years, 132 days ago. Instead of replying here, would creating a new thread be more useful? |
