| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 22:00 - 11 May 2009 Post subject: Resurrection: GSX1400 (Part 2) |
Thought this may interest some of you ...
Link to Part 1 https://www.bikechatforums.com/viewtopic.php?t=173115
Right, here we go ... a rough guide to stripping a 14 engine.
Tools required ... yes ... used my Teng Jumbo 111 piece socket set and a pair of circlip pliers ... jam doughtnuts, cups'o'tea and fags may help as well.
Tip#1 ... look at the bit where I'm stripping the clutch ... do this bit first while the engine is still in the frame as you can put it in gear, put a dod'o'wood through the back wheel and undo the clutch nut ... if you don't do this then you'll need a proper clutch holding tool, or do as I did and cut two flats on a sprocket and then put a big vice on the sprocket to hold it while you undo the clutch nut.
Where possible I'll highlight appropriate bolts etc using yellow marks.
This is the lump out of the frame ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip001.jpg
Undo all the clutch cover nuts ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip002.jpg
Remove the clutch cover and undo the pressure plate bolts in a diagonal sequence to release pressure equally ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip003.jpg
Undo the clutch nut and remove ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip007.jpg
Remove dog drive plate ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip008.jpg
Remove inner clutch basket, drive plates and friction plates ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip009.jpg
Remove outer clutch basket, push the bearing/bush back while doing this (the yellow dot) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip010.jpg
Remove bush, bearing and oil pump drive gear ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip011.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip013.jpg
Right, to the back of the engine, remove all the bolts shown to get oil pipes, camchain tensioner and sensor off ... undo bolts on tensioner equally, it's under pressure from the ratchet spring ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip014.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip015.jpg
Undo these bolts to take air boxy thing off ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip016.jpg
Undo these bolts to remove starter motor ... just pulls out to the right ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip017.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip018.jpg
Breather ................................................... and on we go ...
Undo these bolts to remove signal generator cover ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip019.jpg
Undo this bolt to removal signal generator rotor ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip020.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip021.jpg
Undo these screws to remove signal generator pickup plate and oil pressure sensor wire (need this undone to be able to remove plate) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip022.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip023.jpg
And remove signal generator plate (watch out for dirt/grit trapped in the area above the rubber seal on the wires) ... you may also want to remove the pressure sensor as well to save it getting squashed if you tip the engine over ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip024.jpg
Right onto the alternator casing, undo all these bolts and then carefully pull the casing off ... watch yourself here as the rotor magnets attract the casing quite strongly ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip025.jpg
Pull out starter motor idler gear shaft and remove it and idler gear ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip026.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip027.jpg
Onto the top of the engine next, undo all these bolts to remove cam cover ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip028.jpg
Undo three middle bolts first to remove upper cam chain slider then undo eight camshaft cap bolts to remover the caps (inlet camshaft) ... do these in a diagonal sequence say a turn or two at a time ... the camshaft will be pressing some valves down and not on others, so you want to ensure it comes up as level as possible to prevent any undue stress (caps are marked A/B/C/D with same marks on cylinder head) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip029.jpg
Caps now removed so camshaft is now free to be removed ... lift chain up and take the camshaft out to one side (cams are marked IN and EX so you won't get them mixed up) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip030.jpg
Do the same again for the exhaust camshaft ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip031.jpg
Next undo the two bolts under the front of the cylinder head ... one of these snapped as I undid it, but this doesn't stop you getting the cylinder head off (this was the only bolt that snapped) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip034.jpg
Undo two yellow blob bolts to remove oil feed pipe ... undo the two green blob bolts next and finally the red blobs bolts are the cylinder head bolts and should be undone in a diagonal sequence ... these are feckin tight ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip032.jpg
There are ten long cylinder head bolts to be removed, the other two are studs and have a dome nut on them ... so now that's all done take the cylinder head off ... this may be a little difficult to get off due to the two oil drain tubes at the front being stuck due to road crap ... take your time!!
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip033.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip035.jpg
Barrels are next, you only need to undo one nut for this ... the nut may be rusted on and it'll extract the stud as you undo it ... you won't be able to undo it fully before it foul on the barrels, but once the barrels are lifted slightly you'll be able to undo it fully ... you also need to remove drain tubes as well before lifting barrels ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip036.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip037.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip038.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip039.jpg
Right, this is the bit where I forgot that you need to take the pistons off before you can split the cases ... so no pics of removing one circlip in each piston, then pushing gudgeon pin out to remove piston ... but this is what it looks like with pistons removed (remember which pistons goes where!!) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip048.jpg
Next, splitting the main engine cases ... undo these bolts on the top of the engine first ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip042.jpg
Then turn engine over so you can get to the sump and undo these bolts to remove sump ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip043.jpg
Undo these two bolts to remove oil pickup ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip044.jpg
Remove these two bolts to remove balancer shaft guard, and also remove oil pipe (tight little fecker) ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip045.jpg
Remove all the small yellow blob bolts first (sugar missed a blob to the right of the big copper washer), then undo the red blob bolts in a diagonal sequence ... these are the main crankshaft bolts so will be tight ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip046.jpg
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip047.jpg
Now flip the engine right way up again and lift the top half of the main casing off ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip049.jpg
Lift the gear box shafts out ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip050.jpg
And finally lift the crankshaft out ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip051.jpg
Fed up taking pictures now and stripping, so last bits to be removed are the gear selector drum and shaft ... undoing these screws/bolts will allow these parts to be removed ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip052.jpg
This engine has done just over 46k miles, and the main bearing surfaces are in perfect condition ... they should be a dull grey colour but the picture isn't the best ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip053.jpg
All conrods seem to be in good nick apart from #3 which is a bit stiff ... didn't have the right type of socket to get it off so I'm stuck for now and don't know if it's gubbed or just tight
The bores are perfect looking to the eye and still have the honing marks on them, couldn't believe it!!
Finally ... this is what a GSX1400 engine looks like mostly stripped down ...
https://i16.photobucket.com/albums/b9/BanditsHigh/GSX1400_Engine_Strip/GSX1400_Engine_Strip054.jpg
Hope you found this interesting
All the best ... Barry |
| 400bandit |
 400bandit World Chat Champion
 Posted: 23:50 - 11 May 2009 Post subject: |
Awesome write up there, always had a soft spot for them. Is it going back standard? Would be a shame to not at least fetle with her now she's all stripped down like...
Joe ____________________ Current Bikes 650 Honda Bros, VTR1000 Firestorm // Past Bikes: Sachs Madass 50/110cc - Bandit 400 - FZR750
(+ a XS650 in lots of pieces in my garage and other places...) |
| alun111 |
 alun111 World Chat Champion
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 00:55 - 12 May 2009 Post subject: |
Tip of the day: Stick an elastic band on one end of your gear shafts and pull it round to the other side, stops the cogs sliding off accidentally, can be a bitch to put it all back together
Looking forward to seeing what this turns into  ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 04:24 - 12 May 2009 Post subject: |
im guessing you had some valve to piston contact? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| chris-red |
| BanditsHigh |
| Big Rab |
 Big Rab World Chat Champion
 Posted: 07:51 - 12 May 2009 Post subject: |
Brilliant piece of work there
Brings back memories when i stripped my GS850 and restored it.
First time I had stripped and built a Suzuki engine, quite easy really, just have to do it methodically, take pics and remember where it all goes, trying not to have any bits left over
I cant wait to see the finished bike now, have you set a time limit to finish the bike.
Rab
Good luck  |
| BanditsHigh |
| 400bandit |
| BanditsHigh |
| Mr.Everready |
 Mr.Everready World Chat Champion
| MaybeGuy |
 Posted: 11:32 - 12 May 2009 Post subject: |
| DaveH |
 DaveH World Chat Champion
| BanditsHigh |
| MaybeGuy |
 Posted: 12:47 - 12 May 2009 Post subject: |
i know theyre meant to have recesses for the valves, but the inside left seems to have metal swarf in it ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Davie_G71 |
 Davie_G71 World Chat Champion
| DaveH |
| druidsam |
 druidsam Crazy Courier
 Posted: 13:34 - 12 May 2009 Post subject: |
good work barry, very informative
........................Sam ____________________ trust me! I'm a druid
https://www.bikerforum.co.uk/ |
| mapex |
 mapex World Chat Champion
 Posted: 16:40 - 12 May 2009 Post subject: |
Brilliant big man....well laid out post and
a good post for anyone doing the same
but with less skill. ____________________ www.soundclick.com/foursticks |
| BanditsHigh |
| BanditsHigh |
| MaybeGuy |
 Posted: 20:44 - 12 May 2009 Post subject: |
i think you need a really close DI of journal 3. it wont have done it any good. personally i wouldnt re-use that journal if it did that. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Wise1 |
 Wise1 World Chat Champion
 Posted: 20:54 - 12 May 2009 Post subject: |
Nice job Fudnut.....
Will come round this week and have a look.
You done work to the house?
....Just thought I would ask  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
| husky |
 husky Nitrous Nuisance
 Posted: 00:42 - 13 May 2009 Post subject: |
excellent and informative as normal barry  |
The last post was made 17 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
