XJ600 Speedo and tyres?
acydbyrn
PostPosted: 13:04 - 11 May 2009    Post subject: XJ600 Speedo and tyres? Reply with quote
Does anybody know of problems with the speedo mech at the wheel of the (Pre div) XJ600.
I assumed the cable had gone so replaced it but after some testing I've determined that the Clocks and new cable are fine leaving the only culprit to be the assembly bit at the wheel.
I'm no spanner whiz so any help appreciated.
Also my rear tyre is getting down to the wear line. So what tyres come recommended? I hear alot of good things about BT45's, and prices seem reasonable (though I've never bought a new bike tyre so dont know).
Can you get 'run flats' for bikes?
mattjs895
PostPosted: 14:35 - 11 May 2009    Post subject: Reply with quote
just got some bt45's for my xj600, i cant see or say anything wrong with them tbh, better than i expected really. hold up well in the wet as well.
as for the speedo, i believe it might be a broken speedo clutch, as i have had 2 fail on my over the last couple of months.
cheers
matt
acydbyrn
PostPosted: 15:00 - 11 May 2009    Post subject: Reply with quote
matt, any idea where these are available, price and is it something that can be fitted easily or does the whole wheel need come off?
How much ti you pay for your BT45's? A place I found (online) wants around 65 for the front and 75 for the rear...then obviuosly I gotta pay for fitting!
M1ke
Ped Boi
PostPosted: 17:34 - 11 May 2009    Post subject: Reply with quote
https://cgi.ebay.co.uk/BREAKING-PARTS-XJ600-XJ-600-PRE-DIVERSION-SPEEDO-DRIVE_W0QQitemZ120356731914QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item120356731914&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Wheel needs to come off to fit.
mattjs895
PostPosted: 09:52 - 12 May 2009    Post subject: Reply with quote
i got mine from a local tyre fitting shop, but m and p online or your local dealer might be able to help.
but with the speedo take the wheel off first to see whats going on, take a picture and post on here if you have to.
cheers
matt
iooi
PostPosted: 15:50 - 12 May 2009    Post subject: Reply with quote
Bt 45 work well on a Xj 6...
Whatever you do, do not let them sell you Avon Road Riders......
Thom
PostPosted: 15:52 - 12 May 2009    Post subject: Reply with quote
have you been using standard grease on the speedo drive? the previous owner had problems with this on his and found the nylon thing inside it had swollen and melted under friction. it turns out the grease had reacted with it. i think it was graphite grease your meant to use or silicon although i dont remember.
Whip the speedo drive off and have a peek its a 5 minute job!
Thom
PostPosted: 15:54 - 12 May 2009    Post subject: Reply with quote
Also...
I use BT45's religously. ive got both front and rear tyres down to with a 1/4" of the edge and thats because i ground out the rhs footpeg at that point.
acydbyrn
PostPosted: 16:04 - 12 May 2009    Post subject: Reply with quote
metalforever, what profile ones did you get? I have a sneaky feeling that the ones on it are not right as they seem a bit square
The last post was made 17 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 60.77 Kb
