99-02 r6
Ben.
PostPosted: 17:25 - 13 May 2009    Post subject: 99-02 r6 Reply with quote
going to do an r1 front end, and an 03-05 r6 rear end.
Will also do an 05 gearbox swap but not at the moment, i want to do something to the engine but can find anything, cant find a big bore kit/ high lift cams. dont want to do anything to the engine that will make it unreliable, i.e lightened crank/ con rods etc. Might have a fuck around with the carbs once ive done everything else.
I wont be adding things like changeing brake discs or putting K+N filters on, simply because they are a 5 min. swap, that every r6 owner has done.
R1 front end:
forks are getting completley rebuilt, new springs and seals, all new bearings (wheels, steering), r1 yokes, r1 mudguard, r1 clip ons.
r6 swingarm:
got an 05 shock, swingarm, brake caliper.
getting 07 r6 wheels powder coated white, and the swingarm sandblasted back to alluminum.
the forks will make the bike more twitchy because of the rake angle, which will give a better turn in, it will help the brakeing with the increased strength in USD forks. The swingarm is a tad longer than the old r6 (1 link longer chain), which will help mid corner stability, but make the bike slightly slower to turn in, it also raises the ride hight, im going to keep the front ride hight the same which leaves the forks sticking out a couple 2" or so. undecided where to put the clip ons yet, above or below the tripple tree...
this has been tried and tested and it is an improvment to the old system, of course re doing r6 forks and putting a better rear shock will also improve an r6, but im also doing this for cosmetic reasons.
first picture i have:
https://i44.tinypic.com/353b5tk.jpg
will be adding pictures at each stage and doing a proper write up.
follow my racing season
Race bike - R6
Road bike - sv650
McGee
O RLY?
PostPosted: 19:28 - 13 May 2009    Post subject: Reply with quote
Shall be interesting looking forward to it.
Its pronounced Jixxer!
TUG
PostPosted: 20:40 - 13 May 2009    Post subject: Reply with quote
Good luck. Thumbs Up
Haz ER-5, innit!
jack_zxr400
cant wait to see how it ends up!
although im waiting for someone to say 'why bother?' xD
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
TUG
PostPosted: 20:43 - 13 May 2009    Post subject: Reply with quote
Lol whats the point? If we say it he spits his dummy out and crys a bit. Laughing
Haz ER-5, innit!
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 08:06 - 14 May 2009    Post subject: Re: 99-02 r6 Reply with quote
If you're using the same yokes (or triple tree as the yanks say) then you're not making a difference to the rake at all. Simply changing the forks wouldn't have an affect on this. Confused
Unless you can tell me how I'm talking a load of arse.
Thom
PostPosted: 08:18 - 14 May 2009    Post subject: Reply with quote
I was going to say the same thing big ham, all i can presume is that the USD's are slightly longer? so he thinks by raising the front end of the bike he thinks hes increasing rake?
Infact the only way you could change the rake was by having a different steerer tube angle, or different yokes which are angled slightly.
Edited: Typo Embarassed
PostPosted: 08:27 - 14 May 2009    Post subject: Reply with quote
metalforever wrote:
I was going to say the same thing big ham, all i can presume is that the USD's are slightly longer? so he thinks by raising the front end of the bike hes increasing rake?
Since rake is measured as an angle so the length of the forks won't affect it, and with longer forks with it steer in the more leisurely fashion anyway, but this could be counteracted by pulling the forks through the yokes.....
Gazdaman
I did a trackday!!!
PostPosted: 12:46 - 14 May 2009    Post subject: Reply with quote
If the forks are longer the rake angle will change, because it will pivot around the rear axle. Think of it in extremes shorter forks will make the rake angle closer to vertical. Longer forks will make the angle closer to horizontal.
But drop them through the yokes to keep the same geometry and it's all good.
Gaz
S1KE
PostPosted: 20:52 - 14 May 2009    Post subject: Reply with quote
the R6 will look the nutz with USD's on it.
cant wait to see it.
hurry up
Laughing Laughing Laughing
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
Scouse
PostPosted: 19:55 - 16 May 2009    Post subject: Reply with quote
I looked at doing this but it looks a right cunt to get the forks right. I've read about having to mix and match yokes etc from the R1 and R6 to stop the front wheel sitting in the belly pan 'V' piece. Seems a bit too much hassle. Would be so much easier to slot later R6 forks straight in. Would probably be lighter too.
jack_zxr400
PostPosted: 21:31 - 16 May 2009    Post subject: Reply with quote
You need the triple clamps from an R1 with the stem from an R6
Current Bike: R6
TUG
PostPosted: 23:15 - 16 May 2009    Post subject: Reply with quote
If it was me makin this bike, i'd of made an R61, lol.
Haz ER-5, innit!
PostPosted: 08:12 - 17 May 2009    Post subject: Reply with quote
Gaz
Aaa, never thought of it like that. Thumbs Up
Scouse
PostPosted: 20:46 - 22 May 2009    Post subject: Reply with quote
Well.................................?
Anything new?
SM.Morgan
PostPosted: 23:55 - 22 May 2009    Post subject: Re: 99-02 r6 Reply with quote
And you work as a mechanic?
Then you'd know that changing the cams or fitting a big bore kit would be alot less reliable than fitting aftermarket con-rods or lightening the crank.
If you want to improve performance then, i'd start with finding a company which will be able to provide forged internals so that you can up the power more.
Lightening the crank and fly wheel should make the engine rev-up easier, which would be a good place to start.
Harley XR1200
TUG
PostPosted: 20:36 - 23 May 2009    Post subject: Re: 99-02 r6 Reply with quote
He knows what hes doing, leave him to it. He likes learning the hard way like SV650's need oil.
Haz ER-5, innit!
PostPosted: 01:34 - 25 May 2009    Post subject: Re: 99-02 r6 Reply with quote
Lightening interals seems an expensive place to starting, getting a set of performance cams of getting the current ones reground would.
The bike with standard internals should be fine for a bit of tuning maybe 10/20% increase.
L-Jam
PostPosted: 01:45 - 25 May 2009    Post subject: Reply with quote
Soooo ... Liar
Journalist, student, egotist.
L-Jam
PostPosted: 19:55 - 05 Jun 2009    Post subject: Reply with quote
Sooooooooooooooooooooo...... Brick Wall
TUG
PostPosted: 21:30 - 05 Jun 2009    Post subject: Reply with quote
Yea cmon, wheres the updates then? christ i start the SRAD rebuild soon...
Haz ER-5, innit!
The last post was made 17 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 119.57 Kb
