| M1ke |
 M1ke Ped Boi
 Posted: 22:13 - 14 Jul 2002 Post subject: Can someone offer any help? |
I just got this second hand 1999 RS125 (rossi replica)
Anyway its been ok for about 50-60km but now its having a few problems
I was over-taking a car in 3rd gear it was *just* reaching the power band (8000rpm) when it lost all power and eventually came to a stop (no matter what gear i shifted into) Anyway i pushed the dame thing home because I couldnt get it started again. After leaving it 20 minutes I had a go at starting it and it was fine until... I shifted into 3rd gear, reached 8000rpm and it did exactly the same thing. Its now having troubles at 2500rpm as well (stuttering/cutting out)
My first thought is that the power valve is sticking but would this also stop it from starting??
If it isnt the power valve what the hell is the problem?
Thanks in advance for any help you can offer |
| TiN |
 TiN Pocket Tin
| M1ke |
 M1ke Ped Boi
 Posted: 22:23 - 14 Jul 2002 Post subject: |
thanks for the quick reply.
Well i have checked the oil and petrol as the first things...
when you say air box what could be wrong with that? and how do i check that its working? To be honest I dont know what the hell the air box does, im guessing it regulates the air flow into the engine....
I have had the side fairing off for a quick look but didnt really do anything as my knowledge of bikes is very limited
When you say plugs you mean spark plug? I wouldnt think the bike would start if the spark plug had stopped working, correct me if im wrong. |
| Ropehead |
 Ropehead Could Be A Chat Bot
| M1ke |
 M1ke Ped Boi
| McJamweasel |
 McJamweasel BCF Junkie
| Ropehead |
| M1ke |
 M1ke Ped Boi
 Posted: 22:41 - 14 Jul 2002 Post subject: |
maybe keith will know
This is annoying, i dont suppose the guy i bought the bike off will have it back now. Maybe it is only a minnor fault. The thing that made me think that its the power valve is that it keeps f*cking up just at the point were it opens/shuts.
I will take it down to the garage on tuesday or something but it better not be anything big or i'll be really pissed off.
I will take it out tomorrow if i have chance to see if it has corrected its self as I was stopping, starting alot today (i am getting used to the gears in other words) In the past week it has been redlined a few times as im new to the whole idea of gears and i have stalled it rather alot when pulling away. Im hoping i havent caused this problem. |
| bikerboy1 |
 bikerboy1 Trackday Trickster
| M1ke |
 M1ke Ped Boi
 Posted: 23:20 - 14 Jul 2002 Post subject: |
i never turn it off mate thanks for the help though i wish it were that simple |
| TiN |
 TiN Pocket Tin
| Hunter |
 Hunter Nitrous Nuisance
 Posted: 17:57 - 15 Jul 2002 Post subject: |
Hey newbie..!
Better get it checked by a pro mate... sounds to me like the carb just needs a bit of cleaning.
Usually after you buy a bike.. you have to check and clean these things cause you never know how the earlier guy used it and maybe it was just sitting in a garage for sometime, if it was then its quite likely that the foam in the airbox was a clogged and may have deteriorated over time.
Its unlikely that its the CDI or electics, but could be.. get those checked as well.
Its not a stuck powervalve thats for sure.
bikes, even aprilias , can take quite a beating! So I don't think its cause you stalled it a couple of times or the fact taht you redlined it. |
| Keen |
 Keen World Chat Champion
 Posted: 18:06 - 15 Jul 2002 Post subject: |
I think you should start turning the fuel tap off after use- leaving it on causes damage I think, especially on 2 strokes.
My Cagiva does the same thing- only its less selective about when it does it. It runs for 10 minutes then does that. Italian bikes are shite  |
| Robby |
 Robby Dirty Old Man
| Scooby |
 Scooby Scrappy Doo
| Keen |
| Hunter |
 Posted: 18:07 - 16 Jul 2002 Post subject: |
Keen.. the carb you have should have 3 breather lines coming out of going apparently nowhere
The oil and the petrol lines to the carb are the only ones that should be attached on the other end.
I think I have a picture...
This one shows the carb with ONLY breather lines attached.. yes it is dirty and i've cleaned it up since
https://www.technolanka.net/finnpack/nsr/DSCF0083a.JPG
and these are all the carb bits.. in case you want to take your carb apart
https://www.technolanka.net/finnpack/nsr/DSCF0121a.JPG |
| Keen |
 Posted: 19:03 - 16 Jul 2002 Post subject: |
I still haven't got around to looking at it- but thats good to know cos there's two tubes coming out of the top that both go nowhere- I don't know alot about carbs but I thought that was too many before now
In fact I'm gonna go have a look at it now The weather's fantastic and I cant ride my bike  |
| M1ke |
 M1ke Ped Boi
 Posted: 01:05 - 20 Jul 2002 Post subject: |
Well... I seem to have fixed the problem
When i said i had checked the fuel i meant I had opened the tank and given it a shake and i could see loads of fuel in there... However I filled it up and it works again...
Is the reserve petrol in the same tank or something? cause i swear i could see loads of fuel sloshing around!
Thanks for all your help
Regards,
newbie  |
| McJamweasel |
| TiN |
 TiN Pocket Tin
 Posted: 08:43 - 20 Jul 2002 Post subject: |
The reserve facility simply uses a shorter tube, so it can suck in fuel that is lower down in the tank...you can run on reserve constantly for normal riding, but it's not advisable, as when you run out of petrol, you run out!
Tin ____________________ TiN
dotgems.net |
| TJ NSR |
 TJ NSR World Chat Champion
| Robby |
 Robby Dirty Old Man
The last post was made 23 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
