Dell Mini Insparon 910
Colin Edwards
PostPosted: 11:03 - 16 May 2009    Post subject: Dell Mini Insparon 910 Reply with quote
Hi,
I have one of the above. I need to rebuild it but I dont have the recovery bits.. Any one have an image or the software.. Or even how its done..
Thanks
Colin Edwards
PostPosted: 11:49 - 16 May 2009    Post subject: Reply with quote
Dont worry.. Google was by best friend..
If anyone else has to build a mini its all here - https://www.eeeguides.com/2007/11/installing-windows-xp-from-usb-thumb.html
Works for all mini's apparently
CE
PostPosted: 12:14 - 16 May 2009    Post subject: Reply with quote
Dell have all the drivers you need on their site :-
https://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRON910&os=WW1&osl=en&catid=&impid=
Colin Edwards
PostPosted: 12:18 - 16 May 2009    Post subject: Reply with quote
Got all the drivers.. Was trying to work the best method to install..
THe link above I posted shows how to create the USB drive needed to boot then install. I couldnt get it to boot from USB CD..
Worked well..
Colin
Seb
PostPosted: 00:44 - 17 May 2009    Post subject: Reply with quote
Dell mini 9s have a nasty bug in the bios which causes it's install CD to ask for the path for each and every last file as it installs windows, was that the problem you had?
If so, fiddle with the boot order in the bios, I can't remember which way round you need it, but thats the main cause.
2010 Triumph 1050 Sprint ST
Colin Edwards
PostPosted: 07:43 - 17 May 2009    Post subject: Reply with quote
I dont have the recovery CD that came with it..
To add to that it doesn't see the USB DVD drive I have.
I used the above link to create a bootable USB drive.
I then had to flash the bios and this involved creating a dos bootable USB drive different from the FAT32 Windows one.
I then discovere the Windows CD was the wrong one as it had been taylourered by DEll for another model. This meant I had to copy some files manually.
I thn got - "...biosinfo.inf could not be loaded. The error code is 14
Setup cannot continue. Press any key to exit" and gave up.
I created a Ubuntu USB install and it worked fine. Problem is a job for a freind who wants Windows...
Do you still think its a boot order issue? Any advise?
Thanks in advance.
Colin
Seb
PostPosted: 12:55 - 17 May 2009    Post subject: Reply with quote
Hard to say, I could get through the first stage of windows setup with no problems, it was the second stage (Once it reboots into the GUI) where they tend to go pear shaped for me. I've not got one in stock at the moment otherwise I'd upload an ISO, if I remember right, it's pretty typical fare for Dell though, a lightly modified windows CD with all the machine specific drivers on a separate CD.
I'd fiddle with the boot order just to rule it out if nothing else Thumbs Up
Colin Edwards
PostPosted: 20:44 - 17 May 2009    Post subject: Reply with quote
Going to try media from VLK/select tomorow and changing boot order of course...
Thanks.. CE
The last post was made 17 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 57.14 Kb
