Jetting a NS125R for a Arrows Pipe
clemsta
PostPosted: 17:24 - 31 May 2004    Post subject: Jetting a NS125R for a Arrows Pipe Reply with quote
I'm about to de-restrict my bike, i have been able to get a cheap second hand arrows system, i have been told that i need to re-jet the bike, what size of jet should i use, how many jets are there that need to be replaced, can i buy a kit and if so where from and how much. Laughing
Thanks for your help. Thumbs Up
hollamat
PostPosted: 20:45 - 31 May 2004    Post subject: jets? Reply with quote
try www.dellorto.com main jets are £2.95 each.
They may also be able to give you advice on jets sizes!
clemsta
PostPosted: 22:13 - 31 May 2004    Post subject: Reply with quote
I've had a look bu it doesn't mention my bike, i e-mailed them anyway. Has anyone else got any suggestions
bikedudextrm
PostPosted: 04:13 - 01 Jun 2004    Post subject: Reply with quote
Just see what size main jet is in your bike at the moment, fit the exhaust and up jet a couple sizes, see how it runs and check the condition of the plug and up jet more if necessary until it's runs correct.
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
clemsta
PostPosted: 13:57 - 01 Jun 2004    Post subject: Reply with quote
Thanks for the info, i've been told that the standard jet size is 110, is it just the main jet that you change, has anyone done what i am about to do?
What did you do? Razz
ts50x0
PostPosted: 17:25 - 07 Jun 2004    Post subject: Reply with quote
i havre not done an nsr but on my 50 when i put on a racing exhaust i put one in that was one size bigger. that is just the ,mamin jet and it was perfect so just up the main jet size by a bit and check the plug each time. in the haynes manuals they show you what to look for in a plug and if its runing too hot, cold ect......
hope that helps Thumbs Up
clemsta
PostPosted: 18:12 - 07 Jun 2004    Post subject: Reply with quote
ok thanks, the exhaust was damaged when it arrived so i sent it back, i was thinking about derestricting the standard pipe instead. I only need the bike until the end of the year, then i will be getting a 400 if i pass my test
nsr125sp
PostPosted: 00:11 - 08 Jun 2004    Post subject: re Reply with quote
Hello i have just fitted a new arrow system to my nsr, the standard jet size is 135 and believe it or not i had to lean it off as it was too rich, i have gone down to a 130 in stages which has made it better, aprrently on some high performance 2 strokes this is needed to get the max performance, check the plug also !!
ollie
Nsr 125, Vfr 400
https://www.bikepics.com/members/nsr125sp/
The last post was made 22 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 56.12 Kb
