Thats never used to happen..
B10Hazard
PostPosted: 18:06 - 16 May 2009    Post subject: Thats never used to happen.. Reply with quote
When i start my computer up it allready has open my documents in explore mode.
Can anyone help.
It never used to do this and i have nnot changed anything.
Thank you in anticipation Cool
No longer any socks
The Artist
PostPosted: 20:41 - 17 May 2009    Post subject: Reply with quote
start
run
msnconfig
startup
check down there for anything unusual
PostPosted: 20:43 - 17 May 2009    Post subject: Reply with quote
allymoss wrote:
start
run
msnconfig
startup
Might have more success with "msconfig" Thumbs Up
Pickledswede
PostPosted: 22:16 - 17 May 2009    Post subject: Reply with quote
Isn't there an options menu somewhere, where you can select what you want to run when you turn on your computer? Might be something to do with that, but I'm no expert..
Scotsman37
PostPosted: 03:49 - 18 May 2009    Post subject: Reply with quote
What's listed within the 'Startup' located within the 'Programs' via 'Start' ?
iooi
PostPosted: 09:47 - 18 May 2009    Post subject: Reply with quote
How do I stop My Documents window from opening at startup?
This is a question I received a while ago. After an upgrade to Windows XP SP2 the 'My Documents' folder always opened when Windows was started.
I ran msconfig, but couldn't find anything suspicious... After a while I found out there was something wrong with the 'userinit'-key in the registry.
The value of this key (HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\UserInit) was C:\WINDOWS\system32\userinit.exe,C:\WINDOWS\system32\userinit.exe.
Changing this key to only C:\WINDOWS\system32\userinit.exe solved the problem.
It works as well.... Mr. Green
Start/Run/regedit hit enter
Then in registry editor do CTRL-F and enter in the txt box userinit.exe. This will find the line you need to edit. Double click on the userinit.exe to select it, this opens a txt box, replace whats in there with C:\WINDOWS\system32\userinit.exe
B10Hazard
PostPosted: 13:48 - 18 May 2009    Post subject: Reply with quote
awsome.
thanks allot
No longer any socks
The last post was made 17 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 52.17 Kb
