crank bearings shot---need help on replacements.
spitfire123
PostPosted: 20:39 - 18 May 2009    Post subject: crank bearings shot---need help on replacements. Reply with quote
right,
just discoverd that my main bearings are gone..the have movment in the L/H side.
so....
the ones allready on it have rubber seals on the outside edges of the bearing.....
there is this set on ebay from a fellow on here i belive:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120421808148&ssPageName=ADME:X:RTQ:GB:1123
he advises me that they are 'caged bearings' and do not need the rubber/plastic seals and assures me these are better quality for that.
but this dearer set of £40 apears to come with rubber seals for the bearings as i would of though they should?no?
here is the link:
https://cgi.ebay.co.uk/Cagiva-Mito-125-Main-Bearing-Seal-Kit-crank-bearing_W0QQitemZ370186418229QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item370186418229&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
so do they or do they not need the oil seals?
it says in the description they are bioth c4 bearings? im presuming there the same?
any help is MUCH arpiciated.
CHEERS Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
spitfire123
PostPosted: 21:14 - 18 May 2009    Post subject: Re: crank bearings shot---need help on replacements. Reply with quote
ok the boots ove found from the diogram are external and go over to protetct gearbox oil from entering the engine.
aso:
is it possible to remove the bearing without splitting the engine and just slotting the new bearings in,lol?
cheers
PostPosted: 21:17 - 18 May 2009    Post subject: Reply with quote
Never seen a sealed bearing used on a 2 stroke crack, and would expect the drag from the bearings running in grease to be rather greater.
PostPosted: 21:27 - 18 May 2009    Post subject: Reply with quote
But, if you buy sealed ones, it is a matter of a few seconds to ping the seals out using a small, pointy screwdriver.
My Number 1 piece of advice is to take the old ones with you to a bearing factors and ask them to supply you with new ones. Look in the yellow pages under bearing factors. It will usually be called Town name Bearings and Transmissions. Don't go in there asking for one for a Cagiva, you'll only piss them off, take the old one.
If you are replacing the mains, do the oil seals at the same time. You'll be proper pissed off if you get it all together and the seals leak (believe me!).
spitfire123
PostPosted: 22:08 - 18 May 2009    Post subject: Reply with quote
yep ill be replacing the oil seals to.
as fo rthe bearing im gonna get some off the internet for it.
cheers Thumbs Up
spitfire123
PostPosted: 10:20 - 19 May 2009    Post subject: Reply with quote
is it acturly possible to remove the bearings and slot new ones in without splitting the engine?
cheers
PostPosted: 10:37 - 19 May 2009    Post subject: Reply with quote
Nope, you need to split the crankcases.
spitfire123
PostPosted: 11:14 - 19 May 2009    Post subject: Reply with quote
damm it Laughing
also is that why this bike vibrates alot a t top end?
because no-matter what i do with the balancer shaft its still shakey past 6k
PostPosted: 11:22 - 19 May 2009    Post subject: Reply with quote
Could well be. How much play is there on the end of the crank?
spitfire123
PostPosted: 12:52 - 19 May 2009    Post subject: Reply with quote
well when i changed the magnito and had the flywheel off there was abit of side to side play in it.
thats whan i though it neened chamnging and assumed thats why its been vibrating alot?
am i right?
PostPosted: 13:07 - 19 May 2009    Post subject: Reply with quote
Possible, but normally they whine when they wear out. I would be be inclined to check elsewhere as well (eg, big end bearing condition, even a piston that is heavier / lighter than standard).
spitfire123
PostPosted: 13:24 - 19 May 2009    Post subject: Reply with quote
piston was changed 300 miles ago.
replaced with a mitaka (same as top end) dome head.
is there anywhere i can JUST buy big end bearings from and not the whole set?
PostPosted: 13:27 - 19 May 2009    Post subject: Reply with quote
Not really, as the chances are that a shot big end bearing will have wrecked the con rod and the big end pin, hence they are normally sold as a set.
Pressing the crank apart and back together with the new parts and truing it all up is a skilled job.
spitfire123
PostPosted: 13:40 - 19 May 2009    Post subject: Reply with quote
well thers no knocking or 'wuring' just vibrates...
but i do know the crank bearings need chhaning.
however....i do have areplacement crank out of anothe rengine which is fine so i may use that instead a sthat allready has the conrod etc on it.
what do you recon?
PostPosted: 13:59 - 19 May 2009    Post subject: Reply with quote
Personally if you are going to the effort and expense of a full strip down then just put a new con rod kit in it.
spitfire123
PostPosted: 14:59 - 19 May 2009    Post subject: Reply with quote
hi mate,
well the previous owner had it rebuilt through cagiva (this was about 3k ago)
the bike has done 9-11k miles rioughly.
PostPosted: 15:12 - 19 May 2009    Post subject: Reply with quote
Could be that the person who did the last crank rebuild didn't know what they were doing and didn't true it up.
I know that with the RS125, cack handed assembly (ie, tightening the bolts that hold the crankcase halves together to pull the crank halves onto the crank) will wreck the main bearings quite repidly.
spitfire123
PostPosted: 11:35 - 02 Jun 2009    Post subject: Reply with quote
hi,
well no i tapped mine in strait.
not that rs way Laughing
cheers
PostPosted: 12:13 - 02 Jun 2009    Post subject: Reply with quote
Idea is that you pull the crank into the bearing, rather than push the bearing / crankcase half onto crank. Result should be a tiny amount of side to side movement in the crank.
spitfire123
PostPosted: 19:03 - 02 Jun 2009    Post subject: Reply with quote
yep there is a very tiny amount of play an dthe engine runs as sweet as a nut Thumbs Up
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 115.65 Kb
