Laptop woes
RealNinja
PostPosted: 07:11 - 19 May 2009    Post subject: Laptop woes Reply with quote
I have recently been given a laptop by my boss who has no use for it anymore (she bought a new one cos this was running really slowly)
I had a look at the HD space etc etc and it was in major need of an overhaul, so I have reformatted the HD.
I reinstalled windows no problem yesterday and all was working fine, I reinstalled spyware and a virus checker, put up the firewall and connected to the net. Still things were fine.
The I decided to try turning it off and starting up again, to boot from the HD.....
It nows runs as slow as it did before and will lock up for no apparant reason....
Suggestions please?!
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
Seb
PostPosted: 08:46 - 19 May 2009    Post subject: Reply with quote
Get a smart checker (Make sure smart is enabled in the bios as well) and check out the state of the HDD, it could well be reallocating sectors due to faults elsewhere which would explain the big performance drop.
Something like Active Boot Disk will do the job nicely.
2010 Triumph 1050 Sprint ST
map
Mr Calendar
PostPosted: 08:52 - 19 May 2009    Post subject: Reply with quote
Drivers?
Did you get the latest from the manufacturers site?
Also what version of Windows are you using and what memory does it have?
As well as the HD check it might be worth downloading the Microsoft memory checker - click here.
NSR Mick
PostPosted: 10:19 - 19 May 2009    Post subject: Reply with quote
Also try checking the CPU fan isnt clogged up.
RealNinja
PostPosted: 10:43 - 19 May 2009    Post subject: Reply with quote
I have an update...
it seems to work perfectly ok until I install any windows updates and then throws a complete fit and won't do anything after rebooting...
no keyboard input, no pointer movement, nothing....
To the point where it won't turn off either...?!
map
Mr Calendar
PostPosted: 12:54 - 19 May 2009    Post subject: Reply with quote
RealNinja wrote:
...work perfectly ok until I install any windows updates...
I say again "What version of Windows?"
If Vista (any flavour) try XP.
If XP make sure it's Service Pack 3.
RealNinja
PostPosted: 15:40 - 19 May 2009    Post subject: Reply with quote
I have installed SP2 off my disc, but then got about 35 updates for it to install.
XP OS
Would it not try to download SP3 when it did the updates?
Interestingly, it's working again now....but i'm not convinced of it's stability.
EDIT - 1g of RAM Wink
Seb
PostPosted: 17:58 - 19 May 2009    Post subject: Reply with quote
Have you run a SMART disk check yet?
RealNinja
PostPosted: 19:40 - 19 May 2009    Post subject: Reply with quote
I haven't yet....
I was going great guns, it was running fine with SP2, so I installed SP3 and it lost the drivers for the modem, so now i can't connect to the net anymore, without networking it to my PC
and I aint doing that until I know this thing isn't virused to death!
My main concern is the complete lack of stability, one minute it's fine the next it's locking up and crashing.....
Seb
PostPosted: 21:36 - 19 May 2009    Post subject: Reply with quote
Rule out hardware issues first of all.
A memory tester wouldn't hurt either, it's a 30 second download after all
https://www.memtest.org/
And then for the love of god, get a proper hard drive tester like active boot disk going, windows scandisk won't tell you the full story on a modern drive.
RealNinja
PostPosted: 08:03 - 21 May 2009    Post subject: Reply with quote
Nobody move!
It's working (i'm typing this on it)
It's running service pack 3 (but dont tell it)
It's still connecting to the 'net
and
I can turn it off and on when i want!!!
Thanks to everyone that suggested stuff to try, I will dispatch karma across the board Thumbs Up
The last post was made 17 years, 113 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 69.56 Kb
