| damz |
 damz World Chat Champion
 Posted: 05:17 - 22 May 2009 Post subject: Project FZR 250 |
Bought this bike as a winter hack but winter was already over so barely been using it since i got it. however i feel like doing some work on it to get it looking and running better.
bit of info on the bike, The fzr (stands for four stroke racer, even though it uses a z) this was one of the smaller bikes at only 250cc but despite its small capacity it still puts out around 45 bhp by revving the tiny engine to 18,500 rpm, so the piston moves at over 300 times per second .
this was it originally
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR250.jpg?t=1242965740
and what it looked like when i got it
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/DSC01102.jpg?t=1242965740
the owner before had someone ride the bike into a hedge and the fairings got damaged so just removed them. was tempted to try and get it back to looking standard but fairings are more expensive than the bike!.
anyway here are some more pics of it and what iv'e done so far
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR/100_0281.jpg
(old chain and sprocket) also you can spot the exup cables and rotor in this picture in the top left, its pretty cool when you turn the key as the electric gismo's make all kinds of whirring sounds.
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR/100_0282.jpg
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR/100_0287.jpg
as you can see the tachometer starts at 3k rpm lol
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR/100_0292.jpg
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/FZR/100_0274.jpg
oil filter is going to be a pain in the ass to replace due to its location, it is located within the engine casing and requires you to lie under it, under lots of small screws/nuts/bolts which is located just above the exup valve so you have to remove the exhaust to get at it and have the bike a fair bit off the ground. so im expecting cylinder head bolts to snap, exup cables to get fucked and the screws to get to the oil filter to be rusty,seized and rounded
basically iv'e taken off the screen straight way, replaced the grips and repainted the mirrors, did this the day i got it.
since then i have replaced spark plugs, chain and sprocket and wheel bearings, new brake pads, new brake fluid and took apart the calipers for a good old clean. next on my list is oil and filter.
slight problem when i tried to remove a spark plug
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/RVF/100_0231.jpg
https://i626.photobucket.com/albums/tt349/Kaiser_Damz/RVF/100_0232.jpg
the plug snapped when i tried to remove it, it started to move then snapped so luckily i managed to get a flat headed screwdriver to catch on the lip of the plug and twist it out.
my plans for it is to scrap the whole front end as the frame for mirrors and clocks are bent and rusty. going to get rid of the lights and indicators as these are pretty tatty. either going to go for twin headlights in a triumph style or a single headlight. leaning towards triumph style however i cant seem to find any at all, any ideas where to get them? new indicators are a fairly simple task, although i will try and mount them elsewhere on the bike so the forks look less cluttered. Clocks will probobly get replaced however im having dificulty finding clocks that will go up to 18,500 rpm so may have to keep them and try and fix the broken lugs on it.
also as you can tell it has a fair bit of rust on it, going to strip it down and give it a good clean out. also requires a valve clearence as it ticks pretty dam loud. also the pipes are blowing as well so need to sort that out. fuel tap is also wonky as it will only run on reserve.
as you can see i have removed the rear fairings, at that time i was wanting it off to see what it looked like completely devoid of fairings, and i liked the rear subframe, enough that i will try and keep it naked at the back as well. the great thing about the bike is that it has a 400 frame but 250 engine, so theres loads of space within the frame for electrics so i will be trying to shift all the important delicate electrics under the tank and seat and weather proof other exposed areas. also remove the rear seat as i wont be taking pillions on it as well.
tempted to have the blue paint stripped off and repainted in black and get a new black or maybe white seat as i think it would look pretty neat, it would also match my leathers. the wheels look manky in the pictures but have turned out to be quite nice when cleaned.
so on my list of things to get
Headlights, preferably twin style (not dominator or small tube ones, wanting triumph style)
possibly new clocks or some kind of screen, again possibly like a triumph to protect the rear of the clocks from nature.
new mirrors
new paint job
redone electrics and shifting them about
new reg plate, for some reason it doesnt fit the bracket in a normal way
replace indicators
sort out exhaust pipes
any suggestions or ideas for me to use on the bike?
im doing all this myself, with help from friends and not in a rush so shouldnt be too expensive, a few hundred quid will be ok, this is also more of a learning exercise as i will hopefully learn much from this project. ____________________ Current Bikes RVF400 - 94
Cars: RX7 FD, Eunos Roadster
Former Bikes: FZR 250R 89, ZX7R 98 |
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 10:04 - 22 May 2009 Post subject: |
You seem to like removing plastic from the bike, so do you want to sell your front mudguard to me?  |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 11:06 - 22 May 2009 Post subject: |
reminds me of...
https://img30.imageshack.us/img30/9468/188zet.jpg ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| damz |
 Posted: 13:48 - 22 May 2009 Post subject: |
what type of headlight is on that? also im going to keep the mudguard as i rode the other bike without a mudguard for a few days and clogged up the radiator very quickly. ____________________ Current Bikes RVF400 - 94
| MaybeGuy |
 Posted: 14:08 - 22 May 2009 Post subject: |
https://img33.imageshack.us/img33/7251/197v.jpg
no idea what they are ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| neatbik |
 neatbik World Chat Champion
| damz |
| Kickstart |
 Kickstart The Oracle
| damz |
| MaybeGuy |
 Posted: 18:31 - 22 May 2009 Post subject: |
mine had a bar going along the bottom of the 2 that they bolted onto. it fell off though, hence the not being in the pictures.
EDIT: pic of the bike when i finished it, before the bar fell off
https://img40.imageshack.us/img40/2698/145v.jpg
ill do some more whorage if you want  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| damz |
| Steve-D |
 Steve-D World Chat Champion
 Posted: 22:50 - 22 May 2009 Post subject: |
The metal plate should be facing downover, the 2 bars one sits under the leg the other supporting behind the leg.
 ____________________ www.southwestbikers.com
Tristan The said 'Dunno what my pace will be like, fastish slow puncture on the rear and if I go too fast I risk my 'keys' falling out' |
| damz |
| jack_zxr400 |
 jack_zxr400 World Chat Champion
| ben350 |
 ben350 Trackday Trickster
 Posted: 17:21 - 24 May 2009 Post subject: |
Yahoo auctions japan is where to look
Unfortunately very few Japs will ship outside Japan  ____________________ Ducati 996 Biposto
Suzuki Goose 350
DT125R Supermoto (Project) |
| chris-red |
| Kickstart |
 Posted: 10:59 - 25 May 2009 Post subject: |
Agree with the above.
Exhausts work by bouncing pressure waves around, and the lengths are very important for the rpm the exhaust works properly at. Hence at best you would land up with an engine / ignition / intake system all desgined to work best at getting on for 18000rpm, with an exhaust designed to work at 10000rpm.
However if you make the exhaust bore too large you land up losing the pressure waves, and so losing power. The R1 exhaust is almost certainly far larger bore.
| damz |
| binge |
 binge Emo Kiddy
| Kickstart |
| damz |
| Kickstart |
| damz |
| Kickstart |
 Posted: 11:09 - 26 May 2009 Post subject: |
That is why you need someone who knows what they are doing with the exhaust, not the local boy racers place that thinks puttign a drain pipe on a Nova will make it much faster. Probably best to just copy what is already there with correct size pipework.
To be honest the first thing I would investigate is getting that pipe repaired.
Could also be worth trying Motad and see if they make a suitable system.
| Steve-D |
The last post was made 17 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
