| Danzio |
 Danzio Nova Slayer
 Posted: 12:46 - 24 May 2009 Post subject: Honda VFR400 nc30 problem....Help please! |
Ok so i took my vfr for a ride today and its been great weather so i thourght id open it up in the country side abit...
was fine around town through the gears up to 50-60mph but as soon as i took it to about 7 1/2 - 8 thousand rpm it starts to make a really growly noise from the engine, the power which normally helped me hurtle forward feels much more reduces and there is a distinct vibration.
the bike itself is in good working order, fine up till those rpm and it will go to them, all the way to 14500rpm, but its feels like its lost alot of power...
its only just started but need some advice on what to do here, sounds smooth to 8000rpm when it usually picks up but then afterwards dosnt deliver the power ive known it to, sounds more like a v-twin than a four!
anyways heres a good description,
get to 8000rpm, wind it on and its feels like it loses power, sounds like a vtwin, little more vibration and a different exhaust note...
as if i was running out of petrol, but im not, ive checked that!
is it still restricted somewhere? this would be my first guess, either that or a fuelling problem as it wont go past 110mph 180kph.....
im sure it wont be valves, or the carbs as they've just all been serviced and were in good nick anyway.
the bikes done 17300 miles..
HELP!! |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 16:07 - 24 May 2009 Post subject: |
Sounds like it drops a cylinder or two when you hit that RPM.
I would suspect a spark issue, so coils, HT leads, to start. ____________________ My Flickr |
| Frost |
 Frost World Chat Champion
| Phoenix |
 Phoenix Twisted Firestarter
| chris-red |
| binge |
 binge Emo Kiddy
| Danzio |
 Danzio Nova Slayer
 Posted: 14:00 - 25 May 2009 Post subject: |
thanks guys ill check these all today and let you know how it goes,
binge ive never had the speedo off, ever, and i know the restrictors are off as ive had it off the clock many a time.
never been an issue till now but ill have a look at the carbs and the regulator rectifier see what the crack is there, i think the sparkies and ht leads will get a check too.
ill let you know how it goes.
cheers lads  |
| BenBray |
 BenBray Spanner Monkey
| chris-red |
| chris-red |
| binge |
 binge Emo Kiddy
| Phoenix |
| chris-red |
 Posted: 00:23 - 26 May 2009 Post subject: |
| Phoenix wrote: | Chris_red, NC30 plugs are £12 each on gear4bikes, usually £14 or £15 in shops, ER9EH, expensive, you can get a set of 4 off ebay for about £30 though.
The 180km/h restriction does work by cutting the spark I believe, but as he mentioned this is a new problem and he's had it past 180 before so that's not it. Still betting on battery/regulator personally, no point doing the rest before checking those as they're easiest. A new NC30 SH633-12 regulator with heatsink is £30 from china anyway, cheap as, just bought one myself for Blade. |
OOps yeah sorry looked at the older model. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Danzio |
 Danzio Nova Slayer
 Posted: 17:03 - 26 May 2009 Post subject: |
update lads, had a tinker on today checking fuel lines, ht leads spark plugs and other cabling. all fine. checked battery, fine, reg/rec is also fine and is already an aftermarket unit.
vfr 400's dont have side stand engine cut outs, or so my haynes manual suggests so i doubt it would be that either.
just really dont know what it could be. maybe one of you guys could come up and have a look if your near newcastle at all? just a suggestion but it really has to be seen to be understood.
my thourghts now are on restriction and if it was done properly? need to find out how its been undone and make sure nothings been damaged there.
any more ideas get back to me.
cheers.  |
| Danzio |
 Danzio Nova Slayer
 Posted: 08:04 - 27 May 2009 Post subject: |
been thinking more about the problem and im pretty sure it could be fuelling as its like a flat spot when it needs more fuel, this could suggest a clogged jet and or clogged fuel line/filter.
im going to clean them tonight if i get time, anyone have any advice on the cleaning of carbs? im sure on the vfr4 their CV carbs, no?
any of you lads fancy walking me through this dont be afraid to shout up!
cheers lads, help is always appreciated.  |
| binge |
 binge Emo Kiddy
| prawny1 |
 prawny1 World Chat Champion
| Danzio |
 Danzio Nova Slayer
 Posted: 08:57 - 28 May 2009 Post subject: |
ok so i took the bike to the garage last night (fuel station) and filled her with vpower and a little redex.
didnt do much good at first but gave it a hand full this morning and instead of the gurgle i got a full powered flig to 14500 rpm! =D
im suspecting fueling problem to be honest. gonna have to clean her out over this weekend
oh and yes they do have a cut out, only found out yday, i left the side stand down and put it into first. engine clicked off as it should have, so no probs there, appologies ben  |
| Danzio |
 Danzio Nova Slayer
| MarJay |
 MarJay But it's British!
| Phoenix |
| Danzio |
 Danzio Nova Slayer
 Posted: 12:46 - 29 May 2009 Post subject: |
marjay: yeah it will from time to time but when it aint working properly i dont want to stress it to much, and its not restricted as ive checked all that and previously had it maxed out at 15000 in 6th, on a private road ofcourse
do i check the diaphrams by just lifting the carb tops off or what?
or are they, like everything else on the nc30, hidden away so only jap hands can reach em?
racism, my forte'! only joking now! |
| prawny1 |
| Phoenix |
| Danzio |
 Danzio Nova Slayer
 Posted: 09:19 - 01 Jun 2009 Post subject: |
hi guys, bikes sorted.
just like to say thanks for all the help. it was indeed the carbs but more the fact that the jets were gunked up, nothing else. my dada helped me strip them down and clean them all, which took ages!
i also got some new diaphragm tops for a motorcycle dealer and replaced tham just incase.
so again guys thanks for the help.
it always greatly appreciated.  |
The last post was made 17 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
