Simple sprocket question.
Coxyzxr
PostPosted: 11:40 - 26 May 2009    Post subject: Simple sprocket question. Reply with quote
What's going to give better acceleration.
1 tooth down on the front?
or
1 tooth up on the rear?
I know both. But individually?
Kind regards
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Wozza
PostPosted: 11:43 - 26 May 2009    Post subject: Reply with quote
1 down on the front, but it won't make a massive difference.
Mr Hammers
PostPosted: 11:45 - 26 May 2009    Post subject: Reply with quote
A change of 1 tooth on the front equates to 3 or 4 on the rear, I think.
A Guide To Powerbands
Coxyzxr
PostPosted: 11:46 - 26 May 2009    Post subject: Reply with quote
If that's the case I'd guess contrary to first reply by Wozza it would make quite a difference?
Many thanks.
PostPosted: 11:49 - 26 May 2009    Post subject: Reply with quote
Basically 1 tooth on the front will have more effect than 1 on the back. Looking at ZXR750L gearing (16:44) 1 tooth down on the front would be the same as 2.75 teeth up on the back.
How much it will help acceleration will depend on what is the limiting factor. If traction or wheelies are the limiting factor in 1st then no great help, and in any other gear you could probably just change down a gear to gain the same advantage.
Coxyzxr
PostPosted: 11:55 - 26 May 2009    Post subject: Reply with quote
Thanks as always Kickstart.
To be honest just wanting some more accerelation in the shorter gears.
Also the bike never reaches rev out point in top gear/prone on a long... airstrip either. Just always seems about 800rpm away. Thought it'd help with that also. But mainly for more accerelation.
Regards
Wozza
PostPosted: 12:04 - 26 May 2009    Post subject: Reply with quote
Many thanks.
Changing down 1 tooth on the front sprocket alone will make a difference, just not a massive difference. I recently changed 1 down on the front and 2 up on the rear, and the difference wasn't that big. For example in sixth gear, engine revs are about 1k higher than before for a given road speed.
Having said that it depends on bike and gearing and so on... Keith has arrived so no need for me to go on Smile
PostPosted: 12:05 - 26 May 2009    Post subject: Reply with quote
Red line doesn't really indicate where the power / torque ends. It is actually torque that is the important bit (power just means that you can gear it lower for the torque to be geared down less).
Purely by chance in the bath this morning I was reading an old copy of PB with an article on the ZXR750J and ZXR750K. The J made its peak and rapidly fell away after about 9000 rpm.
While you might land up with better acceleration in 2nd gear at Xmph, this is no great gain if you would otherwise still be in 1st with even better acceleration.
Do you have a dyno graph and gearing for your bike? If so can you post them up?
Coxyzxr
PostPosted: 12:16 - 26 May 2009    Post subject: Reply with quote
Thanks again guys/Keith.
I don't have a performance graph.
I read that article too, the power transformer one where they try making the J more like a K?
If I'm honest here: with my zxr you can pretty much crank the throttle as much as you want and know the nose won't lift. (Front end heavy porkers) Sometimes I feel it'd be nice if it did though you know? Maybe first gear power wheelies? even just a bit?
Many thanks.
PostPosted: 15:12 - 26 May 2009    Post subject: Reply with quote
Found a couple of graphs for the ZXR750J. One J1 and one J2, but quite different.
Stuck the details up here. Red line is the J1, blue line the J2 and the green line is the J2 running one tooth lower on the front (15:45 instead of 16:45).
Coxyzxr
PostPosted: 15:17 - 26 May 2009    Post subject: Reply with quote
Thanks Keith.
In laymans terms what's that telling me? Shifting the torque down the range and moving it from the top?
Strange the stock J2 is different to J1 as essentially they were the same machine with an attempted fix on the rear shock, nothing more afaik.
PostPosted: 15:23 - 26 May 2009    Post subject: Reply with quote
Suspect that one might have been a better prepared press machine Wink . Or just the effects of different dynos.
The graph is thrust at the back wheel vertically against speed horizontally, for each gear. The thrust is what is accelerating you.
Coxyzxr
PostPosted: 15:26 - 26 May 2009    Post subject: Reply with quote
Awesome, many thanks.
The last post was made 17 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 83.33 Kb
