| RugbyGriffo |
 RugbyGriffo Two Stroke Sniffer
 Posted: 16:13 - 26 May 2009 Post subject: 70cc Gaskets |
heyy
i Have a Aprilia Rs50 With a 70cc bore Kit, and the gaskets have gone! :O
what gaskets do i need to put back on?
Thanks James ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| SM.Morgan |
 SM.Morgan Traffic Copper
| RugbyGriffo |
 Posted: 11:05 - 27 May 2009 Post subject: |
Umm Well i Bought It With The Bore Kit Already On It?:S ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 11:34 - 27 May 2009 Post subject: |
Head Gaskets!!
No There Were All Snapped When i Opened It Up ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 11:52 - 27 May 2009 Post subject: |
there is one from bottom of piston barrel, which is blue.
and one from under the head which is like a square with 4 circles on it.
and a big circle which i red which goes around the top head.
will put oi pic up in a min. ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 12:03 - 27 May 2009 Post subject: |
Pics ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 12:15 - 27 May 2009 Post subject: |
Thanks, But Will They Be 70cc Gaskets Or 50cc? ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 12:27 - 27 May 2009 Post subject: |
Lol Yeah!
i Can Only See 80cc Gaskets ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 12:52 - 27 May 2009 Post subject: |
Yeah My Piston Is 49mm  ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 13:16 - 27 May 2009 Post subject: |
Thank You Very Much
Does Head Have to Be Torqued? ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
 Posted: 16:09 - 27 May 2009 Post subject: |
im pretty sure thats differnt to the kind he needs.
might work tho.... ____________________ Gilera SC 125 - Current |
| Hutchysrs50 |
| Hutchysrs50 |
| Hutchysrs50 |
 Posted: 17:11 - 27 May 2009 Post subject: |
| CHR15 wrote: | the diameter of the cylinder sleeve (the inside bit of the cylinder ) is increased, and seeing as the gasket that seals that is an o-ring, youl need a bigger o-ring.
also, the size of the entire barrel is bigger, to allow more water around the cylinder to help cool more. due to the extra heat being created.
so yeh, maybe the base gaskets would be the same, but all the top end ones will be bigger on a 70. |
hmm, im not sure!!
i have a 50cc, 50cc re-bore, 70cc and an 80cc kit in my garage, i may check soon if i feel abit better. ____________________ Gilera SC 125 - Current |
| Hutchysrs50 |
 Posted: 17:34 - 27 May 2009 Post subject: |
ok, i can tell you that the gasket kit you sent him will not fit.
also im sticking to my guns on this one, iv went and checked and all the cylinders are the same size, the top gasket is the same, the 4 small 0-rings are the same and the main seal around the piston is the same!!
but not in your case as the piston seal and the 4 o-ring seals are one piece, which means you need a proper one to fit your cylinder head.
also. i have a compleate set that would fit your bike spaire  ____________________ Gilera SC 125 - Current |
| Hutchysrs50 |
 Posted: 17:38 - 27 May 2009 Post subject: |
| RugbyGriffo |
 Posted: 18:23 - 27 May 2009 Post subject: |
Ummm Hii
i Am Pretty Confused Now!!!
So What Do i Need to Buy Please?
Buying a TZR |
| Hutchysrs50 |
| RugbyGriffo |
| Hutchysrs50 |
| RugbyGriffo |
 Posted: 19:12 - 27 May 2009 Post subject: |
Don't Think So, i Have Bought The Bike With The 70cc Bore Kit Already On It :S
What Should i Do? ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| Hutchysrs50 |
| RugbyGriffo |
 Posted: 19:29 - 27 May 2009 Post subject: |
ADDED  ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| RugbyGriffo |
 Posted: 19:54 - 27 May 2009 Post subject: |
Have You Accepted? ____________________ Aprilia Rs50 - For Sale
Buying a TZR |
| Hutchysrs50 |
The last post was made 17 years, 149 days ago. Instead of replying here, would creating a new thread be more useful? |
