Suzuki Sv 650 S 1999 Naked Verison.
Mcyd
PostPosted: 16:58 - 27 May 2009    Post subject: Suzuki Sv 650 S 1999 Naked Verison. Reply with quote
Right yesterday i started my bike as normal ride to work, but i noticed when i was on the A road my rev counter and speedometer was going crazy and my fuel light came on for 10 secs went of and kept doing it till i turned my bike off by work, then i turned it back on and it wont start, i bumpped it to get it home and noticed it wasnt going crazy no more,
ill try and start it and nothing happend no noises or anything.
Can anyone help?
Aprilia Rx 50 - Top Speed 70 - Sold - Honda nsr 125 - Speed 103 - Sold
Aprilia Rs 125 - Top Speed 121 - Sold - Honda Vfr 750 - Top Speed ? - Running
Suzuki Sv 650 S - Top Speed ? - Running - Ish
instigator
PostPosted: 17:42 - 27 May 2009    Post subject: Reply with quote
What's the battery like? What voltage is it at?
Mcyd
PostPosted: 18:46 - 27 May 2009    Post subject: Reply with quote
the battry is 12v, ive charged it up and is fine
PostPosted: 23:30 - 27 May 2009    Post subject: Reply with quote
It should be reading something like 13-14v when healthy and fully charged.
PostPosted: 23:32 - 27 May 2009    Post subject: Reply with quote
To add an irrelevant question:
How can you have an SV 650 S Naked version? Isn't that a faired SV with the fairing ripped off?
Or do you mean an SV650 (sometimes called an SV650N)?
And, who cares what the top speed is? Rolling Eyes
Mcyd
PostPosted: 06:17 - 28 May 2009    Post subject: Reply with quote
why be such a smart arse about the fairing, im just asking for help either help me out or dont bother.
alone
PostPosted: 14:47 - 28 May 2009    Post subject: Reply with quote
He is helping lol What voltage does the battery return? Not a tricky question, and could help solve your problem!
Bikes; '06 Triumph Sprint ST 1050 (for sale) - '95 BMW R1100GS
temeluchus
PostPosted: 14:57 - 28 May 2009    Post subject: Reply with quote
Give the lectrics a good spray of WD40. Allow to drain and treat your bike to a tin of Holts Damp Start Autoplast. You can get it in most car places and Halfords.
PostPosted: 16:09 - 28 May 2009    Post subject: Reply with quote
I don't see how that could help. If his battery isn't producing the right voltage he needs a new battery. The connections etc aren't going to cause a low voltage across the battery.
Also WD40 is not the ideal thing to use. How about switch cleaner and then vaseline?
Mcyd
PostPosted: 17:46 - 28 May 2009    Post subject: Reply with quote
right, well even if the battry isnt the right voltage wouldnt ti sitll make it click at least?
PostPosted: 17:55 - 28 May 2009    Post subject: Reply with quote
Possibly.
The first thing I would do is remove both battery terminals, clean them with switch cleaner, put vaseline on the terminals, charge the battery, re assemble it and try again.
Blue_SV650S
PostPosted: 18:24 - 28 May 2009    Post subject: Reply with quote
Sounds like a blown/loose fuse to me. Possibly the ignition switch connector come loose ...
The fusebox is under the riders seat.
But two questions I am unclear on:-
Are the lights coming on with the ignition? (or is it totally dead)?
Does it turn over (just not fire)?
Mcyd
PostPosted: 19:48 - 28 May 2009    Post subject: Reply with quote
ive checked all the connections and fuses,
but if the battry wasnt working then the light wouldnt work but they are so?
PostPosted: 20:04 - 28 May 2009    Post subject: Reply with quote
It is possible if the battery is knacked, then the headlight will work (as it doesn't draw much current) but the starter solenoid etc doesn't work.
If the battery is sulphated, I've heard that you can temporarily revive it by removing it from the bike, tipping it on its side onto a hard surface (such as a workbench etc). Don't drop it from a height, just push it over. Then right it, charge it and fit it to the bike with plenty of vaseline on the terminals. If this fixes the problem then I'd buy a new battery. Even if it doesn't it could still be the battery.
Clanger
Stirrer
PostPosted: 20:24 - 28 May 2009    Post subject: Reply with quote
My point EXACTLY!!!!
No idea about the other thing you were on about, best ask on www.sv650.org - they know EVERYTHING there is to know about the sv...especially Rictus!!!
Blue_SV650S
PostPosted: 22:40 - 28 May 2009    Post subject: Reply with quote
If the battery is suspected, the best thing to do is to eliminate it from the equation by 'jump leading' the bike from a healthy car battery .... if everything is then ok .. its new battery time.
TUG
PostPosted: 22:49 - 28 May 2009    Post subject: Reply with quote
I'm lost here, it wasnt doing it... but then it started doing it on a straight A road? Confused
This sounds like a connection issue at the back of the clock assy or short somewhere as is always with electrics.
Haz ER-5, innit!
The last post was made 17 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 96.04 Kb
