More horsepower for an MZ ETZ 125cc 2 Stroke?
kirkhopel101
PostPosted: 21:03 - 27 May 2009    Post subject: More horsepower for an MZ ETZ 125cc 2 Stroke? Reply with quote
the subject line basically says it all, anyone have any ideas?
Current Bike - 1989 MZ ETZ 125cc
gavcarter
PostPosted: 21:05 - 27 May 2009    Post subject: Reply with quote
exguats usually the first thing to get replaced on a 2-stroke then big bore and carb tuning....
PostPosted: 21:15 - 27 May 2009    Post subject: Reply with quote
There is a lot you can do to an ETZ to make it faster but it's largely a waste of time and effort.
Oddly, the exhaust design on those MZs is as near to mathematically perfect as you'll get. Even racing MZs usually retain the stock exhaust.
Their main problem is they can't rev up to where their powerband ought to be mathematically due to the length of stroke and the weight on the crank. It would take serious engine work to do anything about this.
As I usually say. It's a cheap, honest 125. Just ride it as it is. Tuning it will just decrease reliability.
You might find that gearing it slightly lower will actually increase the useable speed. They were geared high from the factory to improve fuel economy. As such, it can be tricky to get them going fast enough in third to hook fourth while in the power. Net result is that if you land up in third, you can be stuck there until you get to a hill. Dropping a tooth or two on the front sprocket can make it easier to hook top gear.
temeluchus
PostPosted: 15:09 - 28 May 2009    Post subject: Reply with quote
You can get more aggressive expansion chamber pipes for MZs-mostly from Germany.
More poke top end at the expense of making it peakier.
For example:
https://www.akf-shop.de/shop/product_info.php/info/p1606_exhaust-sport--without-MOT--chrome--ETZ-125-150.html
The last post was made 17 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 40.32 Kb
