TZR Engine questions
binge
Emo Kiddy
PostPosted: 11:00 - 29 May 2009    Post subject: TZR Engine questions Reply with quote
Right, as most of you already know, I am putting a TZR 125 engine in my pit bike. Its coming along alright now and ready to get the engine running.
I need to know what gear box oil I should put in it.
Also im a bit confused with the carb. There is a fuel inlet. Then next to that a pair of metal pipes which look identical. Ive blown down one and the air comes out of the other.
And the oil pump setup. Ive got an inlet pipe on the carb body just where it goes into the inlet manifold, and another small pipe on the inlet manifold its self.
Not sure if thats because its a TZR carb and DT inlet.
Any help would be great.
thanks
Ben
Barry_M2
PostPosted: 11:48 - 29 May 2009    Post subject: Re: TZR Engine questions Reply with quote
Coolant lines Wink You dont 'need' to hook them up, its just to keep the carb from icing up in winter.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
PostPosted: 12:20 - 29 May 2009    Post subject: Reply with quote
On my MZ there is no two stroke oil injection in the carb, its straight into the crankcase.
On my Powervalve there is no injection into the crankcase, only the carb.
On my RGV there was injection into the crankcase and the carb...
I suggest you research how the TZR and DT work, because if you put oil into both you'll just foul up the plugs if it is wrong, and if you put oil into the carb and it doesn't need it, you'll run stupidly lean and pop your engine.
If you've got a DT carb with an oil intake, then I would guess the carb will be jetted to use that oil intake... so that should be OK. You just need to find out if the TZR has both carb and crankcase injection, or just carb. Crankcase injection was hailed as an innovation that would allow lubrication of the major engine components on a closed throttle.
One thing actually, how many oil outlets does the TZR oil pump have?
PostPosted: 12:50 - 29 May 2009    Post subject: Reply with quote
It has one.
Connect the oil pump up to the inlet and block up the fitting on the carb.
10W40 mineral oil will be fine in the gearbox, just change it on a more regular basis than if you used semi-synthetic/synthetic oil.
binge
Emo Kiddy
PostPosted: 13:18 - 29 May 2009    Post subject: Reply with quote
Thanks guys, Im at work at the moment on my mobile so will give karma later.
I had a feeling the carb tubes were for carb heating.
Ben
Barry_M2
PostPosted: 13:56 - 29 May 2009    Post subject: Reply with quote
Ben
So just what I said then yeah!? Laughing
PostPosted: 14:05 - 29 May 2009    Post subject: Reply with quote
ms51ves3 wrote:
It has one.
Fair enough but he'll need to rejet to TZR ish jet sizes to suit not putting the oil through the jet won't he? Or does the oil get squirted into the carb via a separate jet? I don't think that is the case, I think he'll need to rejet.
binge
Emo Kiddy
PostPosted: 14:17 - 29 May 2009    Post subject: Reply with quote
the carb is a tzr one, it's meant to have oil injected into the carb. its the dt inlet that isn't standard. so surely i should block that up.
PostPosted: 14:26 - 29 May 2009    Post subject: Reply with quote
I had another thought:
Being that the engine is not currently oriented in the same way that it was in the TZR frame, you may have lubrication issues with crankcase injection.
It might be worth blocking off the crankcase inlet and just using the carb. It will be easier and there will be less questions over lubrication that way.
PostPosted: 14:52 - 29 May 2009    Post subject: Reply with quote
Yes. Smile
PostPosted: 18:01 - 29 May 2009    Post subject: Reply with quote
The oil either goes straight into the carb via a separate fitting or goes into the inlet via the same fitting.
The orientation shouldn't make a difference and he will not have to re-jet as the oil gets sucked into the engine after the air and fuel have mixed in the carb.
It's up to you Binge which fitting you put the oil outlet tube to, it won't make a difference as it's still going to get in the engine the same way.
binge
Emo Kiddy
PostPosted: 21:09 - 29 May 2009    Post subject: Reply with quote
Okay just got in. Sorry about my stupidity earlier. I was at work, Bike was at home. And I was just thinking about the carb / engine etc.
The Oil inlet on the carb is actually just after the air filter. NOT just before the inlet manifold.
However, surely I wont have to re-jet, Because this is the Standard TZR setup. And its a standard TZR carb I am using. So its always been set up this way anyway.
I pulled the inlet out of the DT manifold, Need to tap the hole and screw a small bolt into it with a smear of silicone to seal that up.
Ben
PostPosted: 21:11 - 29 May 2009    Post subject: Reply with quote
You still won't have to re-jet as the oil isn't being mixed in with the fuel.
Seems strange that the oil inlet goes before the carb slide Confused Never seen that before.
I would still personally rather use the one on the inlet, as oil gets pumped dependant on revs and throttle position so oil would still be going into the engine down a hill, if the oil is getting pumped in behind the slide, in theory you'd get a lack of oil going down hills, then once you open the throttle, it would dump a load of it into the engine.
The last post was made 17 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 16 - Page Size: 85.32 Kb
