WD40
rac3r
PostPosted: 16:27 - 29 May 2009    Post subject: WD40 Reply with quote
What and what not to use it on?
It rained the other day so my bike is quite dirty. I'm probably going to take it in for MOT tomorrow so was just making sure all is good. While doing that I though I'd spray some WD40 on the forks, after I did that I thought Shocked
Basically which parts are ok to use it on?
Chequered Flag
Bendy
Mrs Sensible
PostPosted: 16:28 - 29 May 2009    Post subject: Reply with quote
Don't use it on things that grip. You know, like brakes and tyres...
Acemastr
PostPosted: 16:29 - 29 May 2009    Post subject: Reply with quote
apparently it can eat away at rubber, i've used it pretty much everywhere on the bike, just watch seals etc..
2016 Toyota Tacoma Limited
deanoet
PostPosted: 16:31 - 29 May 2009    Post subject: Reply with quote
It can also damage rubber, and plastics if left on too long
For cleaning just make sure it is well washed off after you have finished. I use it with a tooth brush to get into the various nooks and crannies Smile
Recommended not to use on chains as it can corrode the rubber seals inside it causing siezed links.
The Tot
PostPosted: 17:02 - 29 May 2009    Post subject: Reply with quote
That WD40 debate has long been argued that it's the propellant in the aerosol that forces the WD40 past the O-ring seals. If you use the spray/syphon dispensers, you'll be fine. It's petroleum based so it's just the same as using white spirit or paraffin on a toothbrush and working it in.
Spray it on the fork stanchions it'll be fine; just avoid the disks.
Never argue with autism
PostPosted: 17:14 - 29 May 2009    Post subject: Reply with quote
WD40 doesn't hurt rubber, I had a link to an experiment a guy did in a thread earlier in the year where it was discussed.
craigs23
Mr Muscle
PostPosted: 21:26 - 29 May 2009    Post subject: Reply with quote
I tend to use it around the frame, degreasing wheels, swingarm, etc...works nicely as a finisher on black plastic - but Mr Sheene's better for cheapo bling.
The last post was made 17 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 51.3 Kb
