dt125x really slow pickup at low - med revs
bikersupermot...
PostPosted: 23:41 - 29 May 2009    Post subject: dt125x really slow pickup at low - med revs Reply with quote
hey guys, hoping someones good with 2 strokes here! . got a 2004 dt125x ... has a dep full system on it.
these newer dt's dont hav a rev counter unfort. prob i got is, in town riding, low-medium revs, its just got no go at all. its totally embarassing and im gettin passed by guys on 50cc peds.
but stay in 1st, throttle pinned, revs pick up really slow ... then about top end of medium revs ... i get a tiny splutter an the exhaust note changes ... an suddenly the bike flies ... it'll easily lift the front end....the power comes in hard and violent.
nice maybe on a roads, ... but most of my riding is in town an the lack of accelaration at low revs is dangerous. the revs where the power comes in hard is just too high for a town bike.
im told its likely to be powervalve related. do u guys think the powervalve is broken then? or what cud be wrong?
hope someone can help coz its driving me crazy esp as the weathers so good to be riding but im not gettin on with the bike in the way its riding. thanks.
tinybikes
d-bug
PostPosted: 08:22 - 30 May 2009    Post subject: Reply with quote
hi i dont know the ins and out of your bike but with what your saying , it does sound like the PV is working as your saying around med to high revs ya bike is taking off , so its opening ! , as they come in around 8000 revs well mine does there some might be a little lower or higher
when u turn the bike on do u get a sound , should be like a electric sound from the motor , u get a sound of 2 turns errrrrrrrrrr , errrrrrrrrrrrrr lol
if you do then its fine and the only thing i can say would be to give the carb a good clean , making sure every think is fine and see if its still the same after that
cheers d-bug Very Happy
bikersupermot...
PostPosted: 10:08 - 30 May 2009    Post subject: Reply with quote
hey d-bug, thx for yr reply ... yeah i do get that sound when i turn on the ignition an before i start the bike ...
when i bought the bike it already had the dep pipe on it ... do u think it might not be setup right for that pipe?
im not enjoyin riding it at all coz i cant pull away safely at the traffic lights the way it is ... but my old kmx125 pulls like a train or a diesel car at low revs an at 7000, it pulls hard (but not as hard as the dt does when it hits that certain spot) ... so iv gone back to riding the kmx at the mo till i can get this dt sorted!
tinybikes
PostPosted: 11:11 - 30 May 2009    Post subject: Reply with quote
It still could be the PV. Just because it works when the ignition is turned on, doesn't necessarily mean it is working when he is riding the bike.
What you need to do is take the pulley cover off, let it do it's little check on the ignition, once the check is complete the PV will be in the fully open position. Start the engine and it should turn to the fully closed position, if it doesn't and it stays in the fully open position, you have found your problem.
bikersupermot...
PostPosted: 14:05 - 30 May 2009    Post subject: Reply with quote
hey there ... thanks for that info ... ill hav a look over the weekend! ... let me get this right, ill take the cover off ...
switch on ignition and the valve shud open.
once the engine starts, the valve shud then close.
shud the valve then re-open at a certain point when the engine is running/revved up?
and is it obvious to see the power valve opeing and closing?
thx for yr help there btw.
tinybikes
MaybeGuy
PostPosted: 14:08 - 30 May 2009    Post subject: Reply with quote
it could be adjusted wrong
bikersupermot...
PostPosted: 14:44 - 30 May 2009    Post subject: Reply with quote
hey matts ... can u tell me what im looking for to tell me its adjusted incorrectly or correctly. what do i need to measure to tell me its correctly adjusted or ... if its not correctly adjusted what do i have to do to fix this ... cheers matts
tinybikes
PostPosted: 18:37 - 30 May 2009    Post subject: Reply with quote
The powervalve will be fully open again once you hit 7,000rpm. I'm not too sure but I think the DT PV constantly moves.
Once you have the cover off you will see the pulley moving. It will be very obvious if it is working.
You want to line the hole up with the notch by adjusting the cables if it is not already lined up.
https://www.geocities.com/mjvaakanainen86/ypvs2_iso.jpg
You line it up after you have turned your ignition on and once the PV has stopped moving.
Don't forget though, if you do adjust the cables, you don't want any free play in them or else the PV will rattle about.
bikersupermot...
PostPosted: 22:46 - 30 May 2009    Post subject: Reply with quote
ms51 ... thx loads for the pic - thats really helpful to me. ... i really appreciate u posting the pic. ill hav a look at the valve asap. unfort, gotta work tmrw (-
tinybikes
eazy rider
PostPosted: 23:52 - 30 May 2009    Post subject: Reply with quote
I'm betting the powervalve has been pinned open with the cables unhooked.
I've owned a DT125R a while ago and it was just as you describe, although I did it purposefully as I loved the feeling when it hit the powerband and took off. Was much fun for wheelying.
btw the trick to riding the bike in that state is to keep the revs high both before setting off and when changing up a gear.
stirlinggaz
PostPosted: 03:19 - 31 May 2009    Post subject: Reply with quote
hi,
as above, sound like the powervalve has been pegged open, so your only getting the benefit of it, when you get up into the high revs.
& its running shite low down in the revs.
theres a good step by step guide(with colour pics, wow) to these pv.s over on dtr.net.
cheers,
GAZ
bikersupermot...
PostPosted: 08:13 - 31 May 2009    Post subject: Reply with quote
guys ... thanks for the info an help here ... really really appreciated ... will be lookin at the pv next weekend as iv gotta work today unfort!.
so thanks again big time - i had no idea about the pv but am confident about lookin into it now!.
tinybikes
bikersupermot...
PostPosted: 18:08 - 05 Jun 2009    Post subject: Reply with quote
update on the dt125x! ...
well guys, thanks for all your help! ... some of you were totally right! ... round of applause to ya! Wink
the power valve cables had been disconnected and the valve had been pinned open.
so, the cables are back on again and pin removed, the valve turns fine when ignition switched on/off ...
but, the running is only a tiny bit slightly better in town running/low revs ... still gutless.
and at high revs, the bike suddenly pulls hard and very smoothly ...
so with the power valve working, what do i need to do now to sort out the power delivery - more bottom end and maybe a lil less top end wud be great!
thanks once again guys for yr help on this one!
tinybikes
tutton
PostPosted: 19:03 - 05 Jun 2009    Post subject: Reply with quote
Id suggest sprocket change next?
bikersupermot...
PostPosted: 21:40 - 05 Jun 2009    Post subject: Reply with quote
hey tutton ... funny thats my next job as the chain has a tight spot ... new c&s kit ....
so wot size sprockets u recommend i go for or wot do u use?
tinybikes
The last post was made 17 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 88.96 Kb
