Bike MOTs? price?
spitfire123
PostPosted: 18:09 - 30 May 2009    Post subject: Bike MOTs? price? Reply with quote
hi all,
my bike is due for an MOT the middle of next month.
and idea on the price(bike i have is a cagiva mito 125)?
and what should i look out for?
cheers all Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
Flip
PostPosted: 18:29 - 30 May 2009    Post subject: Reply with quote
I think a bike MOT is just under £30.
If you have a Haynes manual it'll have a MOT guide at the back.
https://www.motuk.com/Motorcycle%20MOT.htm
MattEMulsion
PostPosted: 21:40 - 30 May 2009    Post subject: Reply with quote
£29.20 is the current (maximum) fee set by VOSA.
Yamaha YZF-R6
spitfire123
PostPosted: 21:51 - 30 May 2009    Post subject: Reply with quote
ok cheers lads Thumbs Up
ive acturly in the proces sof rebuilding my bike (about 3rd time)/
ive changed previous
fork seals oil etc...
rear shock
tyres
pads
rear wheel beaings....fronts aswell
spindals
swing arm pivort
usal stuff for an mot so should be okay
just gota change the front pads....there sinterd and didnt even last 2.5k Shocked
chars
Towton 1461
PostPosted: 01:33 - 31 May 2009    Post subject: Reply with quote
I paid £24 for my last MOT. The place that did it gave you
a free re-test if it failed - providing you returned within 10
working days.
It's worth checking out your local Yellow Pages for places that
operate solely as an MOT business, if don't trust garages.
This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief!
1016
PostPosted: 08:05 - 31 May 2009    Post subject: Reply with quote
Might need to check chain/sprockets for wear and right amount of play. also headlamp alignment - (if hasn't been touched since last MOT then probably fine)
spitfire123
PostPosted: 20:05 - 31 May 2009    Post subject: Reply with quote
yea sprockets and chain are both good.
and the headlights have been out many a time and i know they are off.
whats the best way fo alining them?
i have the front fairing off anyways so quick replys will be much apriciated.
1016
PostPosted: 21:24 - 31 May 2009    Post subject: Reply with quote
yours is an Evo right? If you look in the handbook there is a dear little picture (page 143 in MkII book) - if you haven't got handbook i will try and explain :- you need a flat bit of road and a nice flat vertical wall (white garage doors are perfect) You park so front of headlamp is 10 metres away from wall.
Sitting on bike, get someone to measure distance between approx centre of headlamp to the ground. Multiply this figure by .9 (that's POINT 9) then measure and mark a line that high from the ground on the wall/garage door. On Main Beam the top of the main body of light should not be higher than this mark. Hope that helps. Thumbs Up
Norris
PostPosted: 21:59 - 31 May 2009    Post subject: Reply with quote
Cheers for this thread, mine is need asap, and was wondering on prices!
Norris
Current Bike: Suzzy K4 Bandit 600 - Black
The last post was made 17 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 59.54 Kb
