rs125 question
dardappa2004
PostPosted: 23:04 - 30 May 2009    Post subject: rs125 question Reply with quote
hi there fellow bikers,
what would you recommend for an rs125 with a big bore kit on and a cone air filter for jet sizes and needle height? At the minute it has a 155 main jet? i just wanna improve top end as feels as if it stops pulling above 90mph so i dunno???? the spark plug is carbon fouled so how could i also sort this????
Many thanks in advance Thumbs Up Thumbs Up Thumbs Up Thumbs Up
bmwsport
PostPosted: 23:12 - 30 May 2009    Post subject: Reply with quote
155 is pretty heavy.. my f.p rs125 with a arrow exhaust runs a 120.. i take it you have the 28mm carb still?
stirlinggaz
PostPosted: 10:48 - 31 May 2009    Post subject: Reply with quote
hi,
get a few different sized main jets & start plug chopping, lol
but if you still have the standard 28mm carb, then you definately need the vhsb 34mm & manifold.
if its the 34mm carb you already have, that main jet is way too small, you should be looking at around 168+ for a bbk. (which bbk is it?)
cheers,
GAZ
dardappa2004
PostPosted: 18:18 - 31 May 2009    Post subject: Reply with quote
hi there , yea i have a 34mm carb erm i bought a 185 tried that and wouldnt rev past 6000rpm . I have 159cc polini one? Thought that its runnin rich so shouldnt i down size? im really a noob when it comes to carbs Crying or Very sad
dardappa2004
stirlinggaz
PostPosted: 00:34 - 01 Jun 2009    Post subject: Reply with quote
hi,
i wouldnt have thought you would need to go smaller.
i was running with a 162 main jet,34mm carb, jl twin exhaust & vectorcone airfilter.
& that was without a bbk.
get a hanfull of jets & start plug chopping, lol
suppose it depends on what other mods you got? (what exhaust you got?)
still think you should be looking at around 170-175 though.
whats the mixture screw at?
& needle height?
how does it perform throughout the rev range?
it may well be running rich, but not at wot.
hence the need for a plug chop.(with a clean plug)
might just be simply a case of moving the clip on the needle.
cheers,
GAZ
dardappa2004
PostPosted: 10:23 - 01 Jun 2009    Post subject: Reply with quote
i have the exhaust that came with it, its de-catted. ok so ill buy some bigger jets and adjust needle height and guess it trial and error,
Many thanks
Cool
The last post was made 17 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 52.43 Kb
