Fitting new brake seals
puremagic72
PostPosted: 17:14 - 31 May 2009    Post subject: Fitting new brake seals Reply with quote
Hi folks, got some fluid and dust seals on order for my brake calipers on my gsxr750, as the seals are knackered and are showing a bit, just wondered if i have to prize the caliper apart to fit them or can it be done by just taking the pistons out, clean up and refitting seals etc
Understand will have to flush and re-bleed etc, and a good clean.
Thanks,
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Slinn84
PostPosted: 19:52 - 31 May 2009    Post subject: Reply with quote
Depends if you can split your calipers or not.
If you can then its the best way. Dont forget that you need to get the old pistons out somehow, usually using compressed air through the hose inlet at the caliper, or by leaving it all attached and pumping the lever to pop the pistons out (holding the pistons in place as they will prolly come out un-evenly) with the caliper off the discs. The latter can be messy though as the fluid will pour out once the pistons pop.
If you cant split the calipers then you use the same methods. Just make sure that two opposing pistons dont meet in the middle cos then you'll have a nightmare trying to prize them apart.
Other then that replacing seals is easy, just make sure everything is REALLY clean when putting the new ones back in. you dont wanna get any dirt in there
Regards
Bikes: - Honda CBR125, Yamaha YZF600 Thundercat, Suzuki GSX750F. Currently Kawasaki ZZR1200
puremagic72
PostPosted: 20:15 - 31 May 2009    Post subject: Reply with quote
Thanks Slinn84, might have to do it the messy way, as i did clean them a few weeks ago, and noticed the seal was almost coming out on a few,was fine when i cleaned them up for a few days, then went back to being crappy again!
Could'nt even move the pistons out with compressed air! Had to re-fill the system and pump them out as far as poss!
The last post was made 17 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 36.78 Kb
