| kenny |
 kenny Nearly there...
 Posted: 11:47 - 01 Jun 2009 Post subject: SV650 breather for fuel tank |
After several months of fault finding and fixing to fix various problems i have finally got them down to just 1 fault now its my breather on my fuel tank its not working if i run the bike for 5mins it starves itself of fuel and if i leave the fuel cap open when running it it will stay running.
My Question is on the tank where it sinks in for the cap to fit there is a small hole about 3-4mm wide next to where you put the fuel into the tank which i can see runs in the tank, is this my breather pipe or just an out let for over flow of fuel when filling up as i know the breathers are some times in the actual cap itself.
Any info would be great, thanks  ____________________ KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6 |
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| kenny |
| finpos |
 finpos World Chat Champion
 Posted: 13:21 - 01 Jun 2009 Post subject: |
The hole in the tank is a drain for rainwater as you say, and the air bleed for the tank should indeed be in the cap although it's not often obvious where it is (i.e. It may not be an actual hole somewhere you can see). It's usually a bit smarter than that because it's got to stop water getting in.
The other slightly more hideous prospect is that on some very new bikes the cap is completely sealed and there is an emissions reduction system that the tank must vent through - that involves a lot of tubes, electronics, solids and other nonsense. Refer to you manual
f. |
| kenny |
The last post was made 17 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
