laquer...nibing back and finishing off?
spitfire123
PostPosted: 19:44 - 31 May 2009    Post subject: laquer...nibing back and finishing off? Reply with quote
hi all,
at the last stage of the re-spray....ive got the 3 coats of laquer on i needed to...
at the last stage as i think it will dry slight ly bumpy shoud i use 1500 wet/dry paper to nib it bak gently and then use the fine rubbing compound to bring the shine?
of corse ill leave it for around 2 days before doing this....but any painter out there?please advise.
many thanks Thumbs Up
You won't be able to eat my dust......As it'll settle before you get there.
tutton
PostPosted: 23:10 - 31 May 2009    Post subject: Reply with quote
If youve got orange peel, and bits of crud in your top coat layers, by all means take it back a little, I used to use 1500 on a DA disc or 2000 wet and dry sheet for this taking it all back to what looks like a misty/matt top coat, (careful around panel edges and parts which will natually have less paint on them like corners etc) then polishing compound, and if a dark colour a wax may be needed.
spitfire123
PostPosted: 13:52 - 01 Jun 2009    Post subject: Reply with quote
ok cheers for that mate,
will take the laquer back tommrow when its properly dry (left for rougly 48hrs)...
see how she looks!
thanks
tutton
PostPosted: 19:55 - 01 Jun 2009    Post subject: Reply with quote
Just remembered, Use something flat like a block or make your your using your hand as flat as you can, dont want uneven nibbing on the topcoat, can sometimes make it look wavy if you put pressure on certain parts of your hand.
spitfire123
PostPosted: 11:33 - 02 Jun 2009    Post subject: Reply with quote
ok cheers,
had a bit of an upset yesterday with the laquer....
put all the pannels outside and one acterdently fell face down on the grass and left loads of deep marks in it...
left it another 3 hours then sanded them out and sprayed over laquer again.
im going to leave them hangin to atleast tommrow night i think...he laquer is still just to soft!
chars
The last post was made 17 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 45.12 Kb
