| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Hutchysrs50 |
| Hutchysrs50 |
 Posted: 13:14 - 01 Jun 2009 Post subject: |
ok, so the radiator was bone dry
i checked the exspnation bottle and it was full to the rim!
i only filled it up half way last night, whats gone wrong
i took the spark plug out (was quite black)
put the jumper pack on with the plug out and the engine was turning over fine, but im going to take the cylinder head off and check anyway!  ____________________ Gilera SC 125 - Current |
| Hutchysrs50 |
| spitfire123 |
 spitfire123 Could Be A Chat Bot
| Hutchysrs50 |
 Posted: 14:34 - 01 Jun 2009 Post subject: |
| spitfire123 wrote: | | Hutchysrs50 wrote: | just the usual update!
the wierd smell was the gaskets cooking away, great.
the cylinder seems perfectly fine, but the piston has grind marks down both sides. |
oh,
dear,dear,dear,dear.
you say this engine you bought used as you had enough of your other one?
how many miles does this engine have on it, or claimed to have on it when you bought it?
al the best. |
i think its done about 11k miles, but the cylinder head has done just over 700?
its all been re-built not long ago.
anyway, the problem was, that there was no water in the engine anymore, it all went into the exspnation bottle.
im sure going for a long ride, including down the duel carageway flat out in 6th for a while, would cause the engine to cook in this weather and with no water in the engine.
iv built the engine back up, but iv had to use my best parts, a £230 mk race cylinder. filled the radiator back up and it fired straight away.
my problem is, why did this happen in the first place, heres some pictures of the piston, + my radiator cap and the thing beside it, i have no idea what it is tho???
https://www.bikechatforums.com/files/dsc00638_190.jpg
https://www.bikechatforums.com/files/dsc00639_190.jpg
https://www.bikechatforums.com/files/dsc00640.jpg
https://www.bikechatforums.com/files/dsc00641_116.jpg ____________________ Gilera SC 125 - Current |
| Kickstart |
 Posted: 14:44 - 01 Jun 2009 Post subject: |
The bit beside the cap just looks like a clip to stop the cap coming off when you don't want it to.
Person first guess would be that the head gasket leaked, compression then pressurised the cooling system (hence the header tank getting fuller) and either leaked the excess liquid out of sucked it into the combustion chamber.
Think the head gasket is a rubber O ring, in which case check it hasn't cracked.
| Hutchysrs50 |
| Hutchysrs50 |
| Kickstart |
 Posted: 16:35 - 01 Jun 2009 Post subject: |
Expansion tank is just basically a catch tank on most bikes. Somewhere to catch any excess coolant and to allow it to get suck back when pressure in the cooling system drops (probably when it gets cold). However some like the RS125 it is a pressurised part of the cooling system. Not sure of the style on the RS50.
If a head gasket goes then one thing it can do is pressurise the cooling system, pushing coolant out.
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| Hutchysrs50 |
| Hutchysrs50 |
 Posted: 16:51 - 01 Jun 2009 Post subject: |
also, the radiator cap and exspnation bottle are both new  ____________________ Gilera SC 125 - Current |
| Blue_SV650S |
| Hutchysrs50 |
| Hutchysrs50 |
| Blue_SV650S |
| Hutchysrs50 |
| Kickstart |
| Hutchysrs50 |
| Kickstart |
| Pete. |
 Pete. Super Spammer
 Posted: 17:36 - 01 Jun 2009 Post subject: |
It's normal for the level in the expansion bottle to go up when the engine is hot and back down when it cools. The radiator cap will let water by when the pressure gets to about 1.1bar on most bikes, about 16psi. There's not much restriction the other way so it pulls water in from the expansion bottle easily when cooling down, this is a normal process. Your bottle should have a min and a max level on it, you should fill it to between those marks when cold. ____________________ a.k.a 'Geri'
| Blue_SV650S |
| Hutchysrs50 |
The last post was made 17 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
