| xxxscotxxx |
 xxxscotxxx Derestricted Danger
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 06:43 - 02 Jun 2009 Post subject: |
i dont have the diagrams to hand as im no where near my pc,
but how it usually works with...
indicators, is that from the fuse it goes to the relay then to the indicator switch and then to the indicator it self,
now if you arn't getting power to the indicator the first thing to check is that you are getting a continious 12v dc to the relay, if not then check the fuse and do a continuity check from the said fuse to the relay,
if your are getting 12v at the relay then check at the switch for continuity bewteen there and the relay(or the connector that is closest to the switch)
if there is continuity then the next thing is to check the switch itself, from the common wire to each turn wire (at the connector)
if that is ok then i would assume it is the relay that is at fault. as there is bound to be atleast 1 earth still intact... (but you may want to check that as well)
be methodical, start from the beguinning of the circuit and work your way through it untill you find the fault,
chances are there is a corroided wire that looks like its still connected, but with a pull it will break,
good luck, sorry i can't give your more help, but with out the diagram at my fingertips or with out me looking at the bike myself i can't solve the problem for you  ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| andy_82 |
 andy_82 L Plate Warrior
| xxxscotxxx |
| tofu-wtf |
 tofu-wtf Nova Slayer
 Posted: 14:50 - 02 Jun 2009 Post subject: |
you will still get 13v across the battery if the battery is dead because this is the charging voltage that is being delivered. A problem will come if the battery does not retain that charge. Stick it on an optimate charger and see what that does with it. ____________________ Eagles may soar.............but rats don't get sucked through jet engines!!
1999 ZX6r G1.....it makes me smile  |
| xxxscotxxx |
The last post was made 17 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
