Carb Set Up
Hutchysrs50
PostPosted: 18:02 - 02 Jun 2009    Post subject: Carb Set Up Reply with quote
Sooooooooooo
my bikes been running fine apart from a little slow around 4-5k revs (i put the video on last time)
so i took your advice, moved the needle hight up 1, and it was better for a while, unless iv been out for a long time, then its a little wierd again?
so iv moved it up one more spot (its now on the middle grove) i started the bike and it seems fine, idle was higher than usual, so i unscrewed it about 1 and 1/2 turns and its happy around 900 - 1100, but what i want to know is, what do i do with the air mixture screw, im on the understanding that you need to change them both, not just one, so in short...
needle moved down a notch ( the clip moved up to the middle)
idle screw turned out 1 1/2 turns
what do i do with the air screw
Thanks Thumbs Up Karma Mr. Green
Gilera SC 125 - Current
Hutchysrs50
PostPosted: 19:00 - 02 Jun 2009    Post subject: Reply with quote
awhh come on!
iv took all the fairings off, the headlights off, sprayed the headlights, let them dry, put them back on the bike, put the nosecone and right hand fairing back on, and still nothing?
one of you must know how to set up a carb.
spitfire123
PostPosted: 11:53 - 03 Jun 2009    Post subject: Reply with quote
Hutchysrs50 wrote:
awhh come on!
have you cheked for air-leaks?
You won't be able to eat my dust......As it'll settle before you get there.
Hutchysrs50
PostPosted: 01:17 - 04 Jun 2009    Post subject: Reply with quote
CHR15 wrote:
lol, your actualy worse than me and the gpx.
what are you running? 50/80cc? air box? exhaust? jets?
Hey.
engine: high compression crank, standard 50cc cylinder but its an MK pro street one so itss ported etc..
airbox is a malossi K&N filter.
exhaust is an endy twin.
jet is a 120
but all your help wont help me much anymore, iv just added onto my ebay that the carb needs fine tuning, i mean the bike runs and rides ok, just a little slow around 4-5k
i just want the tzr gone and get my bloody new gpr 125!
The last post was made 17 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 40.29 Kb
